Bottom Dash Swap?
Old Nov 12, 2008 | 11:26 AM
zhilton's Avatar
zhilton
Bottom Dash Swap?
I know it's been discussed in great length about putting Up-Fitter switches in '03 & '04 SD...but all of the ones I've read the original dash was used.
https://www.ford-trucks.com/forums/4...info-here.html
But has anyone tried to swap the lower dash portion of a '05 to '07 into a '03 or '04? Thinking out loud here, but would there be any difference in the trucks as far as lower dashes go? If they have, happen to have the part numbers?
Old Nov 12, 2008 | 11:53 AM
elee3's Avatar
elee3
It has been done. I remember reading a thread about it a while back. I think it also requires changing the cup holder, and the colors might not be a perfect match.
Old Nov 12, 2008 | 12:01 PM
elee3's Avatar
elee3
https://www.ford-trucks.com/forums/6...in-action.html
Old Nov 12, 2008 | 12:37 PM
zhilton's Avatar
zhilton
Thank you for pointing that one out...after 7 pages of searching, I had pretty much given up.
Old Nov 16, 2008 | 09:11 PM
strokersace's Avatar
strokersace
Don't give up man. I swapped them in my '02. Should be the same fuse box as yours so wiring is pretty easy. I had to do some trimming on the main dash behind the panel. Also, had to trim a little on the top of the 05 panel due to the clips holes being in a little different location.
Here's the link to when I did mine. I also did the high idle mod, but you'd just need the upfitter install:
https://www.ford-trucks.com/forums/7...ml#post5885336
Post #10 has the pictures.
BTW, I've actually got a lower dash panel like the pic from riggz's truck with the door in it. Have the cupholder too. It's got 2 small holes drilled in it towards the bottom where a cb or something was mounted to it. I don't have the new trash hook though. Let me know if you'd be interested in them.
Old Nov 16, 2008 | 10:47 PM
riggz's Avatar
riggz
That 1st link is my thread from last year. I added the part #s to it, but here they are again for gray:
5C3Z2504302DA Dash Panel $45.13
5C3Z2504810AAD Ashtray/Cupholder $46.15
5C3Z26061B44AAA Trash Hook $37.80
5C3Z2513546DA Storage Box $50.38
5C3Z13D730AAA Upfitter Switches $32.22
6C3Z14A303A Wire Harness/Relays $67.69
5C3Z2513546CAA Cubby next to switches $7.62
Old Nov 16, 2008 | 10:53 PM
zhilton's Avatar
zhilton
The reason I was thinking about swapping the bottom half of my dash is so that I could not only have Upfitter switches...but the brake controller and a clean under dash look with the aftermarket brake control no longer needed. Thanks information and links gentlemen.
Old Nov 16, 2008 | 10:55 PM
riggz's Avatar
riggz
Keep in mind if you add the brake controller you will have to upgrade your brake master cylinder. Also I'm not sure how well the brake controller will sit in behind a 04 dash as there is a slot on the 05+ that it slides into. That slot isn't there on the pre-05s so It may not support it very well.
Old Nov 16, 2008 | 10:56 PM
zhilton's Avatar
zhilton
Gray is what I'm looking for, my interior is the gray leather that the Lariat's were optioned with. Does anyone know what the FoMoCo brake controller part number is? I'm not dead set on going that route, but I'd like to keep my options open. Again, thank you guys allot for all the information.
twack
Sep 19, 2022 08:33 PM
Bladely
Jan 20, 2017 01:00 PM
mj_355
Apr 16, 2015 09:12 PM
NorEasterMA
Aug 21, 2014 06:11 PM
Moon's Dad
Apr 29, 2011 09:03 PM
