Locking Hood Release
Old Nov 12, 2008 | 11:18 AM
garypettengill's Avatar
garypettengill
I'm searching for ideas/solutions for a replacement cable assembly for my locking hood release. Anyone have any ideas/solutions they would like to share?
Old Nov 12, 2008 | 11:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350 // 1978/79 Bronco Locking Hood Cable.
D5DZ16914A .. Hood Cable-Used with Locking Hood Latch / Obsolete
Fits: 1973/79 F100/350 / 1976/80 Granada/Monarch / 1977/80 Lincoln Versailles / 1978/79 Bronco.
All the Versailles had locking hoods, optional on the Granada/Monarch.
Junkyards only, no Ford or L/M dealer, no obsolete parts vendor has any.
The hood latch (E7UZ16700A) is the same as 1975/91 Econoline (it's also OBSOLETE), but the Econoline's locking hood cable will not work, as it's too short.
Old Nov 12, 2008 | 11:32 AM
garypettengill
Originally Posted by UTfball68
There are tooooooooooons of entire assemblies on fleabay. Usually in the $20 range plus shipping. For ease of searching, search "78 79 Bronco"
Yea, I see them there all the time. Problem is that after 30 years the cable housing gets soooooooo brittle that the slightest bend causes it to crack and then the problems start. That is why I'm looking for a replacement cable, housing and all.
Old Nov 12, 2008 | 11:38 AM
garypettengill
The hood latch is still available from Ford as it was also used on 1975/91 Econolines.
The Econoline hood cable will not work, it's too short.
Thanks ND. I was hoping you'd chime in. Your info is always the greatest. I guess what I am hoping for is that someone has gone out and purchased a new piece of cable and housing and made their own new one. I can't see as it would be that hard of a project with a little patience.
Old Nov 12, 2008 | 11:52 AM
NumberDummy
D8TZ16700A .. Locking Hood Latch Kit / Obsolete.
Came with everything: locking latch, cable, cable lock cylinder, attaching hardware, instruction sheet.
This kit was sold at the parts counter, fits 1973/79 F100/350 & 1978/79 Bronco.
Sorry, no one has it either.
Notice I edited post #3: The locking hood latch (E7UZ16700A) is no longer available from Ford.
I just looked, it just went obsolete.
But, there are a few still in stock at various dealers.
Old Nov 12, 2008 | 09:49 PM
X36's Avatar
X36
Theres gotta be a few 80-86 broncs or trks in ur area.Their -T- handled cable are a nice substitute will do.Or like what was said if ya gotta have a locking one.Chk Ebay.I just bought a whole locking setup for $27.00
Old Nov 12, 2008 | 10:31 PM
TexasRho83's Avatar
TexasRho83
Worse comes to worse, swipe one off the ol' walking lawnmower with power assist
Old Nov 12, 2008 | 10:37 PM
masterbeavis's Avatar
masterbeavis
I worry about the wire breaking, I have had to replace more than I care to remember with junkyard units. Is it possible to take the handle assembly apart to get a new piece of wire rope in there? I never bothered looking.
Old Nov 12, 2008 | 10:44 PM
TexasRho83's Avatar
TexasRho83
If I remember correctly, you can slip the cable out of the assembly.
Old Nov 12, 2008 | 10:54 PM
masterbeavis
What secures the end of the wire rope inside the handle? I know at the latch end there is a ferrule(SP) that holds it together.
Old Nov 13, 2008 | 02:39 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Yes, the 1980-1986 cable and handle can be used as a substitute. You have to use the latch from the 1975-1991 Econoline, or 1973-1979.
Old Nov 13, 2008 | 03:02 AM
NumberDummy
Interesting.
I wonder why Ford doesn't show that info in the parts catalog?
The Econoline part number for the latch (E7UZ16700A) replaced the 1973/79 F100/350 & 1978/79 Bronco's part number (D8TZ16700B).
But there's no mention of the 1973/79 F100/350 & 1978/79 Bronco's cable (D5DZ16914A) being replaced by anything.
Old Nov 13, 2008 | 07:00 AM
garypettengill
Got the drill out yesterday and went investigating. Drilled out the 4 rivets holding the handle together and found another ferrule on the end of the cable in the handle. Started talking to some folks I know in the parts store and ended up with a couple of leads to places who might be able to help. One is a boat store. I think the answer here is finding a new piece of cable and housing and building a new one. I will keep everyone posted on my progress on this as I believe there are more out there needing a fix.
Old Nov 13, 2008 | 08:58 AM
X36's Avatar
X36
Interesting.
They probably don't show compatability,because there 2 different things handle wise (1's chrome that locks the othere is just a nonlocking blk T handle).The cables ARE the same lenght though .I don't know though is.Could only a replacement cable be bought back then OR if someone wanted a new cable they had to buy it with the handle.Just a subnote (I know were in a 70's forum) But I believe Ford put the chrome locking T handles on 80-3 Bronco's.When I found the 1st one on a 80's Bronc I figured it was a 70's unit put on,But I'v taken many off a 80's trks at local yards.That's why I believe they where in use till at leat 1983
Old Nov 13, 2008 | 02:38 PM
81-F-150-Explorer
But I believe Ford put the chrome locking T handles on 80-3 Bronco's. When I found the 1st one on a 80's Bronc I figured it was a 70's unit put on,But I'v taken many off a 80's trks at local yards.That's why I believe they where in use till at leat 1983
1980-1986 F-series and Bronco with the security Lock group, had this metal locking handle.
As for the compatibility issue, and why Ford doesn't list this as working, I don't know.
