Today, I rule!
Old Nov 11, 2008 | 10:28 PM
quaddriver's Avatar
quaddriver
Today, I rule!
Started working on a 1982 Pioneer SX3800 I accidently won on ebay...
It seemed the tuner was a bit intermittent. I was actually getting stereo sep at about 15% ref signal strength, but sometimes, no bars on the meter, sometimes a few. So off comes the bottom.
Poking around I find a signal wire from the IF section loose on the board. jumped the trace points - 80% signal using a stupid dipole hung on the kitchen light/fan (oh yeah, I use a $1500 oak table for a stereo workshop!)
gotta clean up the tape mon switches, vol control, balance both need some deoxit. Of course Im gonna balance the amp - who wants to place bets on the DC offset? Im betting <20mv
Old Nov 11, 2008 | 10:41 PM
sierraben's Avatar
sierraben
Nice find. Very nice.
I was going to off my old early eighties Yamaha integrated amp and matching
tuner, but opted to keep them instead. Glad I did.
For some reason, it sounds better than my '95 Yamaha receiver, so guess which
one I'm currently using?
Old Nov 12, 2008 | 08:38 PM
quaddriver's Avatar
quaddriver
I am so in biz....who wants to buy a rock stable perfectly clean amp?
Left DCO: 18mv, right: 43mv, after mr magic screw driver: .9mv each
set the idle current by adjusting the bias voltage on each channel.
turning all the pots to 0 like the SM says left channel: 2v+!!!! (120mv is the first spec)
could not get her lower than 165mv, right channel was bouncing 400mv, then I got it to a 150mv average (2nd adjustment) but it was bouncing and the heat sink was like an exhaust manifold - painful
shut her off, penned a note to an acquaintance at audiokarma.org, came back, flicked it on - stable.
so taking a chance I used the full procedure and set the bias to 120 then 150mv - rock stable, been running now 30 minutes. Im thinking when I had the amp unbalanced the idle bias took off and at zero volume essentially drove her full blast - I recall reading there is some thermal tracking in here...
About to do a full power test into 8 ohm 200w dummies.
What is an SX3800 you ask? a 60wpc amp that has, get this: .005% distortion. and has a phono section s/n ratio about that of CD's (the sx3900 is its muscular older brother - 120w)
Old Nov 12, 2008 | 09:26 PM
sierraben's Avatar
sierraben
Not bad. When I purchased my old Yamaha, the tech took it out of the box, took off the cover,
and ran his test equipment to test the distortion level.
The Yamy specs out at .005% distortion @ 105 watts/rms.
When he tested it, he shook his head. He got readings of .0015% @ 120 watts.
This unit just seems to sound more dynamic than my other Yamy.
Keep your new find. It's a classic.
Old Nov 12, 2008 | 10:04 PM
quaddriver's Avatar
quaddriver
Ilove the sound of the old pioneer silvers...my smallest one (1977 SX450) is only 15 watts, and it has a set of matched pioneer speakers - it will fill your yard with sound and the '50' series I have had are not that great in the distortion department. All the '80' series units put it into the .02-.05 range which is at least 10x better than the crap available today. the 'muscle' 3xxx units are a world unto their own like the D7-d9 servo units or the famous sx-1980 (Id love to have those, I just dont have the $1200 to get a decent fixer-upper)
btw - you might find that your yammie runs stable into 6 or even 4ohm loads and gets near 140-150 watts. The trick is - pc cooling fans on top lifting heat, powered by a small dc transformer. keep em cool. a lot of the amp trannys are unobtanium nowadays
Old Nov 13, 2008 | 03:04 AM
sierraben's Avatar
sierraben
My Yamy does spec out at 180 watts per channel, but that's clipping power, at a so so .5% distortion.
105 per channel is just fine with me.
BTW, I did run an even older Yamy through my first model ESS AMT-1 speakers
that I'm kicking myself in the a$$ first offing those a long time ago.
I do, however, have a pair of old Infinity RSM speakers that just kick butt.
A basic infinite baffle with a 12'' woof, 5'' mid, and the famous EMIT tweeter.
I just have to re-surround the woofs.
Fun Fun Fun
Old Nov 14, 2008 | 07:29 AM
hoosierbaby64's Avatar
hoosierbaby64
I so have not not understood one word any of you said. lol
Old Nov 14, 2008 | 02:57 PM
quaddriver's Avatar
quaddriver
Well since someone said you look like Carly Simon, bring over some Carly simon records (yes records, unless you got SA CDs - leave the regular crap CDs at home) and we will let you hear what a real stereo amp should sound like. Even compare it to the 'top of the line' you can get today, to the middle of the road for 4 manus from the 70's.
Hear the difference bewteen a 'warm pioneer' and a 'non switching pioneer' and a Sansui and a Kenwood, at normal volumes, thru good speakers
Old Nov 15, 2008 | 07:28 AM
four-sixty-power's Avatar
four-sixty-power
okay, whats the dif between SA cds and crap cds? what does SA stand for? I have a few cds from the mid 80s, are they better quality? what should I look for? I buy all my cds from thrift stores...
Old Nov 15, 2008 | 08:23 AM
hoosierbaby64
I have my LPs from high school...Foghat, Sammy Hagar,, Black Sabbath, AC/DC.......
And I still do not undertand wtf y'all are saying
Old Nov 15, 2008 | 09:15 AM
quaddriver's Avatar
quaddriver
SA = super audio. A lot higher sampling rate and better encoding algorithms to produce a fuller signal - standard cds haved a lot of artifacts in them and you can hear the 'slicing' due to the analog signal being broke up. My daily driver here is a 93 VSX602S which still is in the .03% distortion when not using the AV amps - I run thru a 12 band EQ to attenuate the 500-1500hz signals and give a slight boost at 16Khz then into a set of Bose 701SIIs - at 5 watts power - not even breathing hard - its like being live. Tapes - ignore the hiss even on my 18Khz chrome tapes with DB/DC and HX and they are FAR cleaner than CD. play the cds and you will be sitting there and all of a sudden hear something that was not on stage - those are artifacts - the encoding fails since the hash values sometimes have multiple resolutions and the CD player 'get confused'.
Most DVD players btw can do SA CDs (dont do MP3 or WMA CDs and expect good sound - those formats are for Ipods and earbuds only!) and you can get SA CDs at better music stores, sometimes bestbuy, and thru amazon - expect to pay 20-25 each
Old Nov 18, 2008 | 09:40 PM
quaddriver's Avatar
quaddriver
As of 2 hours ago, this 3800 is now my daily driver in this room, replacing my trusty steed - a 780. what a difference in sound. and the 780 does not suck. running into a set of 1977 lafayette criterion L6's
anyone wanna buy a warranted 780 for $75?
Old Nov 18, 2008 | 09:54 PM
ranger56528's Avatar
ranger56528
you guys kill me...my sterio is 25 yrs old,my direct drive turn table needs a new needle, my 45s are old but good, good collection of 33 and 78's,have a box full of 8 tracks and some casettes tapes,think I own maybe 10 cd's......my pioneer system still rocks....
Old Nov 18, 2008 | 10:54 PM
quaddriver's Avatar
quaddriver
what pioner is it? 25 years is 1983ish? sx 5,6,7,8,? d7,9?
Old Nov 19, 2008 | 08:58 AM
hoosierbaby64
OMG I still do not get it. I need to see if the local college offers Pioneer 101
But I have to admit if all this "jargon" were whispered in my ear it you guys could make it sound beyond erotic. lol
