Add-a-leaf?
Old Nov 11, 2008 | 12:03 PM
FordTruckGirl77's Avatar
FordTruckGirl77
Add-a-leaf?
I searched through and havent found to much info. Has anyone added a leaf front and rear on the X? Down the road I plan on lifting the X atleast 6 inches but not for a while. In the mean time I would like to get a 2-3 inch lift without doing to much. Skyjacker has the add-a-leaf and not to expensive. I saw something about needing a trac bar? What is that? Also plan on putting on Bilstiens. The skyjackers say the front is 2 1/2-3 inch and the rear is only 2 so should I replace the rear block for an 1 larger? Thanks for your input!!!
Old Nov 11, 2008 | 12:19 PM
Neal 97 250's Avatar
Neal 97 250
get the add a leaf for front and rear. that little difference from front to rear just levels it out.
Old Nov 11, 2008 | 06:56 PM
brooklyn born's Avatar
brooklyn born
i did the skyjacker add a leaf on my 02 super duty. leveled the truck perfectly without doing anything to the rear. dont know if the same results will happen with an EX. had to remove leaf and add teflon strips between the stock springs and the add a leaf. the squeaking from the leafs rubbing got to be too much.
Old Nov 11, 2008 | 07:09 PM
FordTruckGirl77
Did they squeak right away or did it take some time? Would you suggest I add the teflon strips when I do the leafs or just wait? One of my stock leafs was squeaking like crazy for a while then one day just stopped. Its pretty new too. Im still lopsided too which sucks. Thanks for the input!!!
Old Nov 11, 2008 | 07:17 PM
brooklyn born
it took awhile to start squeaking. the tapered shape of the add a leaf will start to rub your stock spring. it will become more noticeable with time. i went to a heavy truck dealer and purchased two teflon strips (fairly cheap) i was able to get a pry bar between the add a leaf and the stock spring, pry them apart for clearance and a buddy slipped the teflon between the leaf and the stock spring. the noise was gone for good.
Old Nov 11, 2008 | 08:14 PM
aortizexcursion's Avatar
aortizexcursion
Have you considered using leaf springs from the SuperDuties? They should give you the small amount of lift that you want.
Old Nov 11, 2008 | 09:07 PM
FordTruckGirl77
I thought about it, but it would cost more. I plan on in a few years lifting the X a great deal and doing a ton to it so I just want something simple and not cost a ton. I do have a guy who owns a junk yard looking for some for me, so if I can get those cheap then cool. I am also looking for the tow mirrors and an 05 grill... I am hoping I can go myself and pick it apart!!!
Ron94150
Sep 2, 2015 06:41 AM
DHamSTER
Aug 20, 2013 03:09 PM
jaclins
Apr 6, 2012 08:30 AM
speedsauto
Jan 25, 2008 11:23 AM
sandman3510
May 22, 2003 10:55 PM
