2" Lift
Old Aug 19, 2013 | 08:56 PM
DHamSTER's Avatar
DHamSTER
2" Lift
Hi guys,
I plan on getting a 1-3/4" to 2" level kit in the front, add-a-leaf, but what would the best route be to get a 2" lift all the way around the truck? Im looking for quality but something relatively cheap.
Old Aug 19, 2013 | 09:22 PM
JT250's Avatar
JT250
Originally Posted by DHamSTER
Hi guys,
I used a F-350 rear block to level out my front leveling kit. When I bought the truck it had a pro comp leveling kit on it. The front set just a little higher than the rear. The F-350 block made it sit perfect.
Old Aug 19, 2013 | 09:25 PM
DHamSTER's Avatar
DHamSTER
Okay. My front end sits 2" lower than the rear so i want to get a 2" add-a-leaf and then 2" all the way around. I did do a search and 2" block for the rear is what I have found but what about the front?
Old Aug 19, 2013 | 09:28 PM
JT250's Avatar
JT250
Maybe someone else will chime in. I have heard of X code springs but don't know anything about them.
Old Aug 19, 2013 | 09:29 PM
DHamSTER's Avatar
DHamSTER
Alright. Thanks for your help!
Old Aug 19, 2013 | 09:40 PM
jeffreyt's Avatar
jeffreyt
Is everything stock now? If so, then what you want is either a leveling kit or X code springs in the front and replace the rear stock f250 blocks with 4 inch or stock f350 blocks.
The x code springs aren't really a full 2" lift, they are just stiffer than the V codes, therefore dot about an inch higher. The pro comp leveling kit sits a full 2" higher, it's a while new leaf pack ( mine has twin shocks).
jeffreyt's Avatar
jeffreyt
Double post
Old Aug 19, 2013 | 09:42 PM
DHamSTER's Avatar
DHamSTER
Yes I havent done anything to the front or rear yet. So remove the rear blocks with a 4" f350 block and then get x code level in the front? also 4"?
Old Aug 19, 2013 | 10:07 PM
jeffreyt's Avatar
jeffreyt
No, the rear blocks are 2" for a 250 and 4" for a 350. If you go with 4" blocks in the rear, that's a 2" gain. The X code springs will only get you about an inch in the front, so if you want a full 2" you need either an add a leaf or a new leaf pack that is designed to give you 2" of lift.
Old Aug 19, 2013 | 10:09 PM
jeffreyt's Avatar
jeffreyt
This may help. https://www.ford-trucks.com/forums/1...spensions.html
Old Aug 20, 2013 | 03:09 PM
DHamSTER's Avatar
DHamSTER
Thanks Jeff. The F350 block is something I want to do i like the looks of that lift. Not over the top by any means.
Big Hurt
Jan 28, 2016 01:18 PM
mean1500
Sep 15, 2013 12:29 AM
danorules
2004 - 2008 F150
Nov 7, 2011 07:17 AM
lariat79sc
Feb 16, 2008 06:48 AM
RIsuperduty89
Apr 4, 2007 04:06 PM
