casting numbers
Old Nov 11, 2008 | 10:24 AM
royleexx's Avatar
royleexx
casting numbers
hi everyone i have started my project 1955 f 100 my question is i need info bbf motor i have 3 blocks and 8 heads
blocks are
DIVE 6015-A2
DIVE 6015-AA
DIVE A2B
HEADS ARE
4 -DOVE C
2-DOVE A21
2-D2VE
TRYING TO FIND YEAR BUILT AND BEST BLOCK AND HEADS TO REBUILD THANKS ROY
Old Nov 11, 2008 | 10:48 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
You might want to post in the f-100 forum on farther down the page. This forum is for the 2011 Speculated F-100.
Maybe somebody might chime in here, but since this is relatively new thread on the forum not to many people are watching it yet.
Good luck
Old Nov 11, 2008 | 11:11 AM
fking1's Avatar
fking1
Good luck
HUH??
You are on the wrong Forum!!!
Old Nov 11, 2008 | 11:13 AM
fking1's Avatar
fking1
Matbe the Number Dummy will chime in. He has a wealth of info.
Old Nov 11, 2008 | 11:20 AM
BURNSTOUGHFORD
Wow i did, i swear i clicked the 2011 forum and i saw this. Ya my bad i guess, sorry fellas.
Old Nov 12, 2008 | 02:27 PM
mcdonaldm's Avatar
mcdonaldm
all 3 of your blocks are basically the same. they are all D1VE blocks, the last numbers and letters are just revisions to the basic block. they are pretty decent blocks to start with. pick the one that cleans up the best and needs the smallest overbore.
the DOVE - C and The DOVE-a are againt he same head. a is just the first revision and c would be a later revision of the same design. they are closed chamber (75cc) with 2.08" intakes and 1.64" exhausts, screw in studs and rail type rockers. a good starting point for a mild performance build. you can use any combination of these 6 heads. again pikc the two that need the least amount of machine work for your purposes.
the D2VE head are the least desirable of all the factory heads. it is a large open chamber design that was very prone to detonation even in factory trim and 8:1 compression. only used one year (72) and then replaced with the D3VE head. makes a good boat anchor.
so any of the blocks and any of the DOVE heads will make a very decent starting point for a rebuild and project.
rgds
Mike
tbird250
Dec 26, 2010 04:42 PM
royleexx
Nov 11, 2008 12:05 AM
chrepy
Mar 18, 2006 07:32 PM
jjj_85
Mar 30, 2004 09:18 PM
lr
May 27, 2002 08:17 AM
