Dove heads???? amd casting # ?'s?????
Old Mar 21, 2004 | 07:45 PM
jjj_85's Avatar
jjj_85
Question Dove heads???? amd casting # ?'s?????
I found a 429 in my barn today. The casting number on the head is D3VE-A2A I think, it was hard to read, might of been D8VE I number on the block is DIVE-A2B I think, also hard to read. I was curious what I have here, thanks.
Old Mar 23, 2004 | 04:39 AM
Tyrefryer's Avatar
Tyrefryer
what you have is a '71 cast block (good thing) with '73 cast heads (can b bad thing) basically you have very little, and more likely a 460 anyway.
Old Mar 23, 2004 | 12:40 PM
scroob's Avatar
scroob
Not necessarily bad. D1 is a good block casting, and the D3 heads can work very nicely with some decent compression.
Old Mar 23, 2004 | 10:37 PM
jjj_85's Avatar
jjj_85
its a 429, i am positive. The pistons have 429 stamped on the side and my dad checked the crank today, it is a 429 he aquired just before i was born. I guess kids cost alot of money.....too bad, he had good plans for that motor, mine now.
Old Mar 24, 2004 | 03:12 AM
Tyrefryer's Avatar
Tyrefryer
dont get me wrong i use d3's on my own motor and if someone knows what they are doing they flow very well indeed but as is factory standard they are obviously not the best.
I assumed it was a 460 only becuase they are more common, since you actually have it apart i dont doubt it is a 429.
Old Mar 24, 2004 | 05:49 AM
scroob's Avatar
scroob
I've never heard of pistons with "429" stamped on the side. If so, they are rebuilders.
There could be D3 heads but they were put on later.
Old Mar 30, 2004 | 09:18 PM
jjj_85's Avatar
jjj_85
Well...I did some measuring with the mic and it looks like the block is 30 over and those are the matching pistions...I also thought it was odd it was stamped right on the skirt. I also learned this was aquired from a man that was going to put it back together and gave up and gave it to my father a few years back.
redneckchuck
New Member Introductions
Feb 11, 2007 07:14 AM
Mud Rat
Nov 21, 2004 11:22 PM
Brian460
Jul 14, 2002 11:39 AM
chopper
May 14, 2001 02:06 AM
woodyropes
May 30, 2000 04:22 PM
