Cooling Heating Problem::Looking For Part Need Help
Old Nov 11, 2008 | 09:36 AM
69WestCoastFord's Avatar
69WestCoastFord
Check this part out - I was replacing my hoses and came across this elbow to manifold that was all rusted out. Can't find another one anywhere. Any suggestions. Went to the dealership, local auto stores, and even hardware store to make my own. Nothing has worked. Any information will be much appreciated.
http://i36.photobucket.com/albums/e3...chmentaspx.jpg
Old Nov 11, 2008 | 12:35 PM
mcdobson's Avatar
mcdobson
A pipe fitting and a couple of hose barbs should do it, but Numberdummy probably has a part number for it and knows which obsolete supplier has them.
Hang tight and he will most likely chime in.
Old Nov 12, 2008 | 09:22 AM
Freightrain's Avatar
Freightrain
Looks like the return fitting for the base carb heater plate and heater hose into the intake?
How about just eliminating the carb heater and just install a single fitting for the heater?
You should be able to buy the single elbow at any local parts store.
Old Nov 12, 2008 | 07:55 PM
69WestCoastFord
You are exactly right - Thanks for the help !
Old Nov 12, 2008 | 08:05 PM
69WestCoastFord
O real quick though - the elbow that fits this year make and model is almost impossible to find at the local parts store. I had better luck at the hardware store for this one. Thanks for the input
Old Nov 13, 2008 | 06:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Intake Manifold 2 Port Fitting(s) 1965/72 F100/350
There's more than one, and it would have helped if you listed more info...like the engine size and the year, for example.
Freightrain nailed it = Intake manifold 2 port fitting.
Assuming it a 352, 360 or 390:
1965/67 F100/350 352 / 1961/64 passenger cars w/352/390/406/427's: C2SZ9A455A / Obsolete
Green Sales has 13 = 800-543-4959.
1968/72 F100/350 360/390 / 1965/71 passenger cars w/352/390/410/427/428's: C6AZ9A455C / Obsolete
Wesley Obsolete Parts in Liberty KY has ONE = 606-787-5293
That's it, no other obsolete parts vendor has either.
No Ford dealer has either one.
banks7.3
43
Sep 30, 2009 04:40 PM
Brett1989
16
Dec 17, 2007 12:14 PM
DJdemon6696
54
Nov 10, 2007 07:59 AM
exploderjoe
Feb 18, 2007 05:54 AM
jonw351M
Appearance & Dress-Up
Jul 28, 2004 01:20 PM
