Turbo Torque Specs
on
Yes you can stop the leak. You can either go gun ho and cut the barrel completely off, remove the soleniod and weld the holes up. Mine is done that way and it makes turbo removal SO easy!!
The other option is to pull the rod out as far as possible and cut it off then using a pipe plug , thread it into the end of the actuator and plug the smaller hole left.
