e4od in limp mode
Old Nov 10, 2008 | 08:29 AM
magneto259's Avatar
magneto259
e4od in limp mode
Hello all I put a switch in my 97 f350 to manually unlock the torque converter and now the overdrive light flashes off. I heard this is called limp mode. Will this hurt my transmission? I know one thing it shifts firmer now. If I turn the switch to let the computer control the torque converter it still flashes. Will I need to get a code reader to clear out the codes? Is there any way to fool the computer to think it still has control even when I manually unlock it? Thanks in advance!
Old Nov 10, 2008 | 07:28 PM
mike93's Avatar
mike93
The computer probably does not like the interuption. When you interupted the connection the computer thinks the converter clutch has failed "OFF". It may give you a code for a "TCC solenoid circuit failure" #629 for OBDI. For OBD II I do not know the code #.
Old Nov 10, 2008 | 08:12 PM
magneto259's Avatar
magneto259
Do you know if it will hurt the transmission? Thanks for the reply!
Old Nov 14, 2008 | 04:28 AM
magneto259's Avatar
magneto259
I've found a few programmers that will clear the codes and adjust the shift points but I don't know if that will clear up the problem???? Thanks in advance!
Old Nov 16, 2008 | 07:22 PM
bustech81's Avatar
bustech81
Most likely this will not hurt your trans. as it is an enginering design to prevent trans damage is the event of componet failure.
Old Nov 16, 2008 | 10:09 PM
LastSplash's Avatar
LastSplash
If you continue to drive with the transmission in "limp" mode the life of your tranny will be greatly shortened. Limp mode is a programmed feature that allows the transmission to operate with limited functionality in the event that there is a problem with the transmission controls, the limited functionality is accomplished by forcing the transmission control pressure as high as it can go which causes the transmission to delay upshifts and the shifts will be hard, basically the transmission will shift like you have the gas pedal floored all the time.
The reason your transmission is in limp mode is the TCC override switch you installed. When the PCM sends a signal to lock the TCC the PCM compares the engine RPM with the transmission output shaft RPM to verify that the TCC is locked, if the PCM senses slippage it throws a code for the TCC solenoid and the tranny goes into limp mode, the OD OFF light will blink constantly to inform you that it is in limp mode.
Old Nov 17, 2008 | 04:28 AM
magneto259's Avatar
magneto259
Thanks for the replys. The only time it shifts hard is when the computer has control of the torque converter and the od light is flashing but when I manually disable it, it shifts firm and good. I'll try a programmer and see if it will let me adjust the shift points so it won't lockup so early.
scottmcg
1983 - 2012 Ranger & B-Series
18
Sep 21, 2022 06:55 PM
Maathiu Ra Yin
Electrical Systems/Wiring
Oct 18, 2016 09:37 AM
plowboycowboy
Jul 20, 2015 07:44 PM
kingduvall
Jun 23, 2015 09:41 PM
LCAM-01XA
Jul 15, 2011 09:27 PM
