1995 Ford Ranger grill
Old Nov 9, 2008 | 08:55 PM
300 HP's Avatar
300 HP
Hi
I'm a proud owner of a 95 Ranger.
I love the truck, but unfortunatly I don't like the grill on the front of the truck, it's the only flaw.
Yahoo! Image Detail for www.obenaufauctions.com/Oct6,2007-1995FordRanger89kmi.JPG
That is a pic of a 95 grill. I was just curious if there's any other grill I could put on the front of the truck, maybe a Ford Ranger Sport. Just a newer looking grill?
Yahoo! Image Detail for www.brauchauto.com/images/99ranger.jpg
http://www.sport-trucks.com/images/ford-ranger.jpg
I really like the grills from 1999 - 2009. Is there anyway I could buy this type of grill to put on the front of my truck? Either of the two?
Thanks, much appreciated.
Old Nov 10, 2008 | 09:54 AM
michigan66's Avatar
michigan66
LMC Truck lists some options for you.
Old Nov 10, 2008 | 11:16 AM
wendell borror's Avatar
wendell borror
The 93 and some 94"s 4x4 grill was pretty cool, it was also used on the splash. It was color keyed to the body like the sport. Check out the ranger section on ebay and look for a 93 4x4, you'll see what I mean or look for a splash, a lot of them had it as well.
Old Nov 10, 2008 | 07:17 PM
300 HP's Avatar
300 HP
Thanks but I was looking for more along the lines of a newer grill. Like a 99.
Old Nov 10, 2008 | 07:40 PM
michigan66's Avatar
michigan66
Using catalog pictures as a guide, the 98-00 Ranger grille will not fit as a replacement for the 95-97 grille unless you can do some "cutting and pasting."
Old Nov 11, 2008 | 10:57 AM
wendell borror
This is true, thats why I recomended the 93 4x4 grill as it's a direct bolton and looks better than the stocker.
Old Nov 18, 2008 | 07:08 PM
300 HP's Avatar
300 HP
What type of cutting?
What about a Ford Ranger sport grill? Perhaps from a newer model?
They seem to be about the same size.
The 99 Ranger trucks I've seen seem to have the exact same body style just a different grill.
If I were to put one of these on there, how would I go about it?
Old Nov 19, 2008 | 02:21 PM
matt's2.9STX's Avatar
matt's2.9STX
May as well fabricate one to fit inside the headlight shape while you're at it. & see if you can keep the function intact of protecting the radiator while allowing about the same amount of cool air through. Too much & you just create more drag without really helping engine stay cool. I'd just get an unpainted one as you like & paint it with plastic Krylon Fusion. A lot of guys make them out of billet, & or chrome or black mesh which almost always look cooler than any stock types.
Old Nov 19, 2008 | 02:36 PM
matt's2.9STX
O yeah, I forgot something key. I myself like the newer tech of the oem headlight bezels (at least that pass higher power lumens without oddities). But the front clip is your overall limiting factor. You'd essentially need to change at least everything in front of the windshield with most such mods as I've come to understand it. They do make some pretty cool pre-runner front clips of fiberglass that look wild & can even reduce curb weight if built thin enough.
Old Nov 21, 2008 | 10:02 AM
wendell borror
It maybe easier and cheaper just to trade up for a newer truck.
Old Nov 21, 2008 | 02:55 PM
matt's2.9STX
Perhaps for some & that was part of my point. I just try to make the most of its OEM build. Keep the truck neat & the lights clean & polished. I don't think we'll see many street-driven mods like that until these things are old enough to be the next Tin Lizzies.
elgemcdlf
64
Jul 10, 2014 09:07 AM
precisiontile
Oct 16, 2012 08:01 PM
86f350
Dec 14, 2011 11:05 AM
joewaldner
138
Apr 25, 2008 08:16 PM
carp_886
Aug 28, 2006 05:51 AM
