ebpv rod
Old Nov 9, 2008 | 04:43 PM
otpracer100's Avatar
otpracer100
ebpv rod
Where does the other end of the rod go to?Is it possible for an oil leak to come from there?I've got oil on the up-pipe I think. Does not appear the pedastal. I'm getting some serious smoke from near the turbo after I shut her down. Not really wanting that to continue.Thanks
Old Nov 9, 2008 | 04:51 PM
ckal704's Avatar
ckal704
IIRC, the EBPV is actuated by oil pressure. So, I believe you could have a leak there. I will gladly defer to those more experience than I in the workings under the hood, if I am incorrect.
Old Nov 9, 2008 | 06:22 PM
Norton72's Avatar
Norton72
You can absolutely have an oil leak from around the EBPV actuator rod. Unfortunately living in New York, I don't think deleting the EBPV would be a good idea for you. That's just my opinion, there may be others that live in that area that know better. Deleting the EBPV is a common mod to eliminate the possibility of leakage. Otherwise I suppose all there is to do is to tear into it and fix the leak. Here is a link that explains what is inside the EBPV cylinder.
This link details the removal of the turbo and pedestal.
If you decide to do this, let us know. There are a couple of other thinks you might want to know in addition to this.
Old Nov 9, 2008 | 07:04 PM
tjbeggs's Avatar
tjbeggs
Yes it can leak and yes it can be completely removed if you have the ability even in NY. I live in MI and have plenty cold winters I don't miss that junk one bit!
Old Nov 10, 2008 | 09:54 AM
otpracer100
Thanks everyone.I have had the ebpv unhooked for three years. Have'nt missed it a bit. Fuel gelling up,that's a different story.I'm just not really looking forward to removing the turbo. I thought about doing it when I had my power loss problem. I took a couple of the bolts out and realized I need to buy some tools to get it done....Well if that's what I've gotta do then I'll get er done. I don't like leaving things unfixed.
Old Nov 10, 2008 | 10:17 AM
otpracer100
Norton72 rep points sent thanks for the help.
Old Nov 10, 2008 | 10:23 AM
otpracer100
That turbo removal thread is the man. The instructiona and pics are highly detailed and it lets you know exactly when you are going to need a beer.LOL
Old Nov 10, 2008 | 10:25 AM
otpracer100
What needs to be done if I take the solenoid out? I'm sure something will need to be plugged?Yes? Also what else will I need other than new pedistal o-rings?Thanks
Old Nov 10, 2008 | 10:51 AM
Norton72's Avatar
Norton72
If you are following the turbo removal instructions you might want to note these modifications I posted earlier for them.
If you are going to delete the EBPV, you could do what I did and buy a blank turbo pedestal. I got mine from here, not a bad deal for $75. However, it would have been better if the EBPV cylinder had been removed as well, it makes for easier installation. But for the savings I think it was worth the extra hassle of installing, especially since Cody did most of the work!
If you are going to do the delete yourself, I know that you either have to weld up the hole in the EBPV cylinder where the actuator rod comes through, or you have to tap and plug it. I'm not sure about what you do to the other end where the snap ring is. As for the EBPV itself, here is a comprehensive set of instructions on how that is done.
Good luck.
Old Nov 10, 2008 | 11:10 AM
otpracer100
Norton,I think that pedestal looks like a good deal.Are the o-rings in the pic all I will need?Are there any gaskets for the exhaust up pipes I need?
Old Nov 10, 2008 | 11:39 AM
Norton72's Avatar
Norton72
That little kit there has all you need. You won't need any gasket for the uppipe. I was surprised when I got all that. All I thought I was getting was the pedestal.
Old Nov 10, 2008 | 12:03 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
How do you know if the valve is working or not? I have only owned my truck for about 4 months. When I let off the accelerator I do not notice any type of compression breaking. Example if I am going down a hill and let off the rpm's drop to about 500-700 rpms.
Old Nov 10, 2008 | 12:12 PM
Norton72's Avatar
Norton72
Not sure what you are asking. My understanding is that the intended purpose of the EBPV is that it closes when the engine is cold to hold back exhaust gases until the engine is warmed up. In that case I would think that it is temperature controlled. I know that there is a mod that allows you to use the EBPV as an engine brake. Sounds like that is what you are talking about, in which case you would need to perform the mod first.
Old Nov 10, 2008 | 12:14 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
My misunderstanding of its operation. I thought it also worked as an engine break. Thanks for clearing that up for me.
Old Nov 10, 2008 | 12:18 PM
Norton72's Avatar
Norton72
Here is a link to one way to perform this mod.
troy's66customcab
Mar 31, 2012 06:09 PM
jdross440
Aug 2, 2010 01:46 PM
RedRage
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 1, 2006 05:40 PM
fuss
Modular V8 (4.6L, 5.4L)
Feb 18, 2006 10:24 PM
MOOK929RR
Sep 16, 2004 02:24 PM
