highboy front hub questions...
Old Nov 9, 2008 | 01:40 PM
kuch73's Avatar
kuch73
couple of questions about my 77 F250. The front hubs don't seem to lock in. I pulled apart the hubs and cleaned out the old chunky grease, but I've heard about different grease to use. Should it be a lithium based or thicker bearing grease? Also, the metal gasket that goes between the hub and spindle came apart in a few pieces, where can I find new ones, as well as the paper gasket? Can't seem to find them on LMC. Thanks for the help.
Old Nov 9, 2008 | 09:40 PM
KFX400's Avatar
KFX400
I always use anti-seize instead of grease because grease seems to freeze in the winter time and as for your gasket you can use silicone it will work just fine.
JPalmer81
20
Jun 17, 2013 02:16 AM
puller45
May 22, 2011 11:37 PM
Dvandy21
Feb 11, 2011 03:25 PM
Slick2
Nov 24, 2009 12:24 AM
