73 F600 engine ID?
Old Nov 7, 2008 | 05:17 PM
faslane's Avatar
faslane
73 F600 engine ID?
I bought a 73 F600 dump, and the fuel pump is leaking, I went to the parts house and nothing matched, mine has the spin on filter at the bottom of the pump, I have 5 valve cover bolts, and I read if the thermastat housing is pointing up and part of the intake that is a 460? and at the parts house if you look up 73 f350 with 460 it has that type pump. how can I tell what I have without tearing into the motor, I cannot read the green sticker on the driver side valve cover
Thanks in advance
Old Nov 7, 2008 | 06:15 PM
darrenmuncy's Avatar
darrenmuncy
460?
there is a vin number decoder in this group 351,400,429,460 all had t-stat arrangment as you described also 351,400 valve cover was flat only up front where the oil filler capis located and rear where the pvc valve was located.
429,460 valve cover's flat from front to rear.
I hope this helps in some way?
Old Nov 7, 2008 | 07:42 PM
faslane's Avatar
faslane
Here are some pics one of the motor that may help, and the bages on the fenders are gone can you tell if it is a 600 or 700?
but the engine will be a big help
Thanks
fastlane5/Dump Truck - Photobucket - Video and Image Hosting
Old Nov 7, 2008 | 09:23 PM
460swmo's Avatar
460swmo
You have either a 330,361 or a 391 ft which is somewhat similar to a 360,390 fe series.
Old Nov 8, 2008 | 09:17 AM
bcuz1998's Avatar
bcuz1998
460 nailed it. It's an FT engine. FT and FE engines have the 5 bolts on the valve covers. Only way to tell which one you have, is to measure the stroke.
Old Nov 8, 2008 | 03:04 PM
faslane's Avatar
faslane
Would you think any other fuel pumps would interchange, the parts house only goes to f-350 and w-c-m and the 360 90 and 460
Thanks again
Old Nov 8, 2008 | 03:21 PM
rbaker6336's Avatar
rbaker6336
360 fuel pump will fit but if I remember corectly the lines are different
problem with 3rd rate chain part stores they sell auto parts not truck parts
Old Nov 8, 2008 | 05:02 PM
faslane's Avatar
faslane
Till I find one, I will need to move it around some, it is leaking out of the rear weap hole when you shut it off, running it dries up and does not leak, when running is fuel getting into the oil? I just changed it and it was like 10 or more quarts.
Thanks
again
Lane
Old Nov 10, 2008 | 12:03 AM
iceberg210's Avatar
iceberg210
If there is gas in the oil it will be immediately apparent in the smell and look of the fluid that is residing in the crankcase. Make sure not to run it with gas in the oil as it can eat up seals, and also its just not good, given that gas is a solvent and oil is a lubricant. Good luck finding parts for these things its a difficult time I've found. The one piece of advice I can give is that instead of a Shucks or even a Napa if you have a local parts place that's not a chain, many times they have fantastic people who have seen pretty much everything so they might be able to help you.
Old Nov 10, 2008 | 12:26 AM
badass75 hiboy's Avatar
badass75 hiboy
i could have a 359 if there is a napa by u the will have it
cole45
Nov 4, 2010 10:59 AM
7mpg302
Dec 3, 2008 06:17 PM
Abuildr4u
May 16, 2006 10:58 PM
barnstormerjack
Apr 29, 2004 10:47 PM
bigblock460
Jan 10, 2001 03:42 PM
