2000 Ranger wiring problems
Old Nov 9, 2008 | 10:58 AM
sixstringsamurai's Avatar
sixstringsamurai
A couple years ago I had some problems with my Ranger. Basically, the rear window was leaking and whenever it rained, the padding underneath the floor mat would get soaked. Since the floor itself was dry, I didn't even realize, but over time some serious corrosion developed in the connector underneath the driver's seat. Its connector 309 and to fix the problem, I cut the male and female sides off and soldered the wires directly together. Everythings been fine, but now I'm getting EVAP codes off the computer and it seems to be because of this wiring. So does anyone have a fairly detailed wiring diagram so I can trace which wires go where and redo the connections? I guess I really need a diagram for the wiring from the fuel tank since I'm getting a po453 code and also now my gas gauge is always pegged above full. Thanks in advance for any and all help.
Old Nov 9, 2008 | 04:45 PM
Franklin2's Avatar
Franklin2
Try here. These people sell the factory diagrams. www.helminc.com
