Head lights pulsating
Old Oct 25, 2008 | 09:43 PM
buggy65's Avatar
buggy65
I just put the starter switch in my 63 F-100 and now my Head lights pulsate at 5mph +.
Old Oct 26, 2008 | 01:20 PM
Franklin2's Avatar
Franklin2
Make sure your regulator is grounded well. Take a small wire and hook it under one of the regulator mounting bolts and then run it to the neg of the battery.
Old Oct 27, 2008 | 12:31 PM
ReAX's Avatar
ReAX
What is the condition of the battery? The battery is responsible for filtering out the rest of the ripple from your alternator. If it's near old age, you might also consider replacing it.
Old Oct 27, 2008 | 03:35 PM
don merke's Avatar
don merke
i love your quote /and the proofs in the pudding ps all things that are elecrtic are connected as one /shorts/corroson not alowed wee
Old Oct 28, 2008 | 11:31 PM
buggy65's Avatar
buggy65
The battery is new and is the one with the most cranking amp I could find at Walmart it was the onley store open at 10pm Im going to try that wire the volt regulater to the battery.Thanks every body.
Old Oct 29, 2008 | 05:47 AM
don merke's Avatar
don merke
Check Faulty Headlight Switch They Have A Built In [1965= 18 Amp "circuit Breaker"]>shorts/ Poor Grounds >cause Lights To Go Out Do You Hear A Click Then It's A Faulty Sw. /loose Connect. Batt./ Or Poor Conect. To The Light Beams Themselves Will Dim /flicker Run A Wire From Light Beam Housing To Frame Rec.!{the/grounds/ Shorts /corrosion > "nightmare's From Hell"PS RE. CHECK STARTER/ RELY FOR LOOSE CONNECTION 1 WORD "VIBRATION" AT 5 MI.HR.
Old Nov 10, 2008 | 01:45 AM
buggy65's Avatar
buggy65
Its a leaky widow seal know that its been dry out side and not raining its not doing it
