Selection dial on dash
Old Nov 8, 2008 | 07:56 PM
marcus02PSD's Avatar
marcus02PSD
Hello, I recently purchased a 2002 F350 SD 7.3PSD (great condition..love the truck). On the dash board is a selector dial to change where air flow goes (defrost, vent, floor etc and is stuck on defrost. It doesn't matter which selection I choose, it always blows out the defrost. Is the switch bad or resistor...? Help.
Old Nov 8, 2008 | 07:58 PM
megawatt00's Avatar
megawatt00
Welcome to FTE! You may have a vacuume leak. When this happens it defaults to defrost.
Old Nov 8, 2008 | 08:09 PM
marcus02PSD
Could you elaborate more. Where would I start to look?
Old Nov 8, 2008 | 08:11 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Jim probably is right, but check the vacuume pump. On the passenger side, next to the battery there is a vacuume canister and a vacuume pump mounted to the fender. Unplug the vacuume line that feeds the canister, then cycle the key and listen for the vacuume pump to kick on. It could be that your vacuume pump is bad.
Old Nov 8, 2008 | 08:14 PM
marcus02PSD
Thanks for the info!! I will check in the morning.
Old Nov 8, 2008 | 08:18 PM
Steve_250's Avatar
Steve_250
A little help for ya....
https://www.ford-trucks.com/forums/3...-question.html
Old Nov 8, 2008 | 08:24 PM
megawatt00's Avatar
megawatt00
Sorry about that bro I shoulda been more descriptive!
Old Nov 8, 2008 | 09:18 PM
fxstbchopper's Avatar
fxstbchopper
Welcome to the FTE!
If it is a 4x4 check your lines going to the hubs too....
Old Nov 8, 2008 | 09:25 PM
Steve_250's Avatar
Steve_250
That's in the link above....
Didn't feel the need to repeat everything again.
Old Nov 8, 2008 | 09:28 PM
fxstbchopper
I just fixed a truck with the same problem the leak was in the line that engages the locks...
I did not notice your post with the link..
