4x4 problems...
Old Nov 8, 2008 | 05:06 PM
krejci.mike's Avatar
krejci.mike
Angry 4x4 problems...
I bought a 2000 F350 and the 4 wheel drive will not engage. It has shift on the fly but the hubs will also "lock", neither work. I am not sure if I am doing it wrong or maybe it is just not working. any help would be great!
-Mike
Old Nov 8, 2008 | 05:11 PM
HKusp's Avatar
HKusp
Well if the manual locking portion isn't getting it working you need to check the electrical connection on the side of the transfer case. Have someone switch the selector in the cab while you are under there. Tap it with a hammer lightly while they are doing it and see if you can see and hear it switch. If not, there is your problem. Now you have to see where the loss of continuity is in the curcuit.
If the selector is working and you see and hear it move then you have transfer case issues.
Old Nov 8, 2008 | 05:14 PM
HKusp's Avatar
HKusp
Also, check what arod said here:https://www.ford-trucks.com/forums/7...ml#post6736080
Old Nov 8, 2008 | 05:16 PM
krejci.mike
"if the selector is working and you see and hear it move then you have transfer case issues."
and what if it is not working?
Old Nov 8, 2008 | 05:19 PM
HKusp's Avatar
HKusp
Then it's the electric motor attached to it.
Old Nov 8, 2008 | 05:45 PM
krejci.mike
Thanks Jason
Old Nov 8, 2008 | 06:08 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Are you sure the hubs are locking? Turn your switch to the 4x4, then try to turn your front joints. You may need a bar to get them started, but if you can turn the front joints, you are looking for a vacuum leak, or the motor is bad.
Do check to see if the motor is working on the transfer case. I can turn the **** and hear the motor running.
I love the ESOF, but you need to keep on top of it.
Old Nov 9, 2008 | 12:12 AM
krejci.mike
ok I'll try it
bio-d
Jul 26, 2013 01:56 PM
HarleyMark
Apr 16, 2013 01:27 PM
Jet Jockey
1997 - 2003 F150
15
Nov 12, 2008 05:56 AM
76f350spercamprspeal
15
Feb 18, 2008 05:14 AM
