Wipers not working - Quick question
Old Nov 8, 2008 | 03:43 PM
salewit's Avatar
salewit
This is an 84 F250 Diesel w/intermittent wipers. In Northern California it doesn't rain in the summer, so the first rains just came, and my wipers don't work. I tried jiggling them with the switch on, but nothing.
But my big questions is: When I turn the key on, and the wiper switch is either on slow, fast or intermittent, I hear rapid clicking coming from what sounds like under the dash. Is this normal?
I got some info from this topic: https://www.ford-trucks.com/forums/3...ty-wipers.html , but nobody mentioned any rapid clicking which doesn't seem right to me.
Thanks,
Sam
Old Nov 8, 2008 | 05:14 PM
Franklin2's Avatar
Franklin2
The intermittent wipers do have a module under the dash connected to the wiper switch.
Make sure you have voltage on the red wire out at the motor.
Old Nov 8, 2008 | 05:41 PM
fellro86's Avatar
fellro86
The rapid click could be as simple as hte transmission linkage under the cowl being disconnected/broken at the joint...
Old Nov 8, 2008 | 09:29 PM
salewit's Avatar
salewit
I'm not sure I even know what that is, but the rapid clicking ONLY occurs when the wiper switch is on.
Will test for power on the red as soon as the rains let up.
Thanks for the help.
Old Nov 8, 2008 | 09:54 PM
fellro86's Avatar
fellro86
The linkage under the cowl that actually connects the motor to the wiper arms is called a transmission. If the bushing popped off, the motor will still spin, but is not connected to anything, but may come around and hit the linkage,. The motor itself simply rotates in a circle, it is the arrangement of the transmission linkage that gives the back and forth motion.
Old Nov 9, 2008 | 04:13 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Intermittent wiper module will also click fast if it has a ground fault or if there is a fault with one of the components.
When it works normally, it will sound a "Click-Click" everytime it sends a pulse to the motor to operate.
When it has a bad ground, or other fault, it will sound like, "Click-Click-Click-Click-Click-Click-Click" etc...
If it's doing that, check the ground wire for the module, then check the motor, then after that, check the module, they do fail with the broken solder joints like was stated in the thread you posted the link from.
Hope this helps
Old Nov 9, 2008 | 12:34 PM
salewit's Avatar
salewit
Yes that helps a LOT! Actually I think I may just change out the motor as it has been moving slower and slower and jerkier over the years. It's got to be that.
Hope this helps
Old Nov 9, 2008 | 07:07 PM
salewit's Avatar
salewit
Ok, I got it fixed. I pulled the wiper motor (not easy... whose idea was it to put one of the mounting bolts UNDER the cowl thing?), and being the poor broke person I am, I pulled it apart and found that it was seized in one of the bearings. I took it all apart, cleaned it and lubricated all the bearing surfaces, and it works better than ever. Thanks everyone for the help!
ArlyDude
Dec 14, 2014 09:32 PM
devino246
May 23, 2013 11:23 AM
psycho72
Feb 14, 2010 07:45 AM
gopedal
1983 - 2012 Ranger & B-Series
Jun 29, 2009 08:53 AM
