Bronco II Ford Bronco II
90bronco II 4x4 module
Old Nov 8, 2008 | 02:42 PM
bIIcool's Avatar
bIIcool
I have a 90 bronco II that has the push button 4x4. I have been messing around with the 4x4 for awhile. When it first died I knew it was the motor and tried to clean it but that didn't work. At that time when i pressed the button on the module the light would flash several times which I was told was a good sign. Recently I was given a motor that was supposed to be good but when I installed it still didn't work. Now when I press the button on the module it glows a steady red. Does this mean I blew up my module or would having a bad motor attached affect the reading. I have already thought about changing to a manual shifter and transfer case but I want to find out my options before I do that.
Old Nov 21, 2008 | 08:31 AM
ewstrand's Avatar
ewstrand
I believe that if it glows steady red that it means it is in 4x4 but its been a while since after my auto transfer failed the 4th time i switch to manual transfer. However if u are sure that it is not in 4x4 and u are sure the shift motor is good the only thing to do is replace the 4x4 module.
Old Nov 21, 2008 | 10:15 AM
bIIcool's Avatar
bIIcool
I found out that the entire problem was my motor. I installed a new one that I found cheap and everything works fine now. I pressed the button and the led still glows red.
jonc123
Oct 23, 2013 03:58 PM
ctubutis
26
Feb 20, 2013 01:52 AM
chris9n
1983 - 2012 Ranger & B-Series
Dec 5, 2007 12:14 PM
92Ranger4.0
Electrical Systems/Wiring
Jul 18, 2004 06:50 PM
