P1744 Analysis Help Needed
Old Nov 8, 2008 | 11:25 AM
ddunlap's Avatar
ddunlap
OK, I've read and read on this but need some help deciding what to do next. My 99 Expi 4Wd 5.4 4R100 with 223k miles is throwing a P1744 code. No other codes and no flashing OD light. It's probably coincidental but the situation started the day after I had the battery disconnected to R&R the fuel pump.
I started with dropping the pan and cleaning. Only a little sludge and fluid not discolored or smelling burnt. Refilled and flushed using the Mark Kovalsky procedure though I used Mercon V per the new TSB.
Tranny feels good... solid shifts, no slipping but threw the P1744 code again within a few miles of reaching highway speed.
Here's the question for you tranny experts. Obviously, in today's market, with these miles, this truck is worth $2,000 no matter how nice and well maintained it is. What is the chance that this is a solenoid pack which I can replace and/or what is the chance that I have to spend the $1,700 I was quoted to do a complete rebuild?
Is it worth the gamble to R&R the solenoid pack? I realize I'm looking for opinions but i welcome them all.
Thanks for your help.
Dan
Old Nov 9, 2008 | 03:07 PM
ddunlap's Avatar
ddunlap
P1744 Code
Any ideas on this would certainly be appreciated.
Old Nov 10, 2008 | 07:12 AM
projectSHO89's Avatar
projectSHO89
Reset the PCM and retest. Might be an anomoly.
If not, you probably will need a new torque converter after you find out why your TCC apply hydraulic pressure is bleeding low.
Steve
dnr_jordan
Sep 1, 2015 01:36 PM
wastingas
Dec 8, 2012 12:03 PM
allingeneral
Sep 25, 2011 04:47 PM
shaggy_rc
2004 - 2008 F150
Jun 26, 2011 08:58 PM
kenneBF250V10
Apr 16, 2008 09:29 AM
