My rear diff cover is leaking AGAIN!!!
Old Nov 10, 2008 | 12:15 PM
afmech's Avatar
afmech
Originally Posted by SFeintuch
Some of those bolt holes go clear through the housing, If I where you I would remove only the bolt that is leaking and clean it up and put a little RTV sealant on the treads and then keep an eye on it. If it is just that bolt leaking that should solve your problem and no need to remove the cover again. Good Luck.
Very good point here, I would try this prior to pulling your cover off again, and also keep in mind that depending on the quality of the aluminum, it is much more prone to flex which will in-turn cause loose bolts. The RTV will also act as a loc-tite, helping to keep the bolts in place. Time & Money saved!
Old Nov 11, 2008 | 08:52 AM
Dale Seeley's Avatar
Dale Seeley
Maybe not a total hijack, but a slightly different direction on the same topic...
When I recently purchased my 04 2wd 6.0 excursion, the previous owner had a dealership replace the pinion seal and flange under ESP when I noticed some oil slung around.
Fast forward two months and 7000 miles.
I begin to hear a noise, very much like mudder tires on pavement, not real loud, the radio needs to be off to hear it. I assume it's the very old tires, showing wear bars, and replace them.
The noise remains. The noise does not change in coasting down in nuetral with the engine off, with the engine on, the brakes applied or not.
It is loudest at about 30 mph while coasting down, definately related to wheelspeed, so that brought me to the rearend.
No leaks found under inspection, the pinion area does look like it was serviced, so I check the fluid.
Pull the plug, stick my finger in, don't find oil until I touch a surface.
The oil looks good, smells not so good, a light burnt smell.
I top off the diff with mobil 1 75W140 synthetic (only choice in that weight at the local parts store), 28 oz (almost a full quart) are required to top off the diff.
The fill plug appeared to have a thick grey grease coating on the inside surface, much like silver colored anti-sieze and just about as messy. "thick" means at least 3/16" thick, appeared to be placed there on purpose as there was none inside the case.
Test drove after refilling, the noise remains, no worse, no less.
Pinion bearing? It wasn't replaced two months ago.
Clutches making noise? Are there clutches in the rear diff?
Opinions and advice welcome....
Old Nov 11, 2008 | 09:07 AM
katiesdad7's Avatar
katiesdad7
Drain the oil, remove the drive shaft and drive it in 4 wheel drive. Then you will have a FWD. Problem solved!
Old Nov 11, 2008 | 09:18 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Never liked using blue silicone where oil is present. I'd use a gasket, along with the orange silicone. Some blue I'm sure is fine when used around oil, but some of it is only for water locations like thermostat housings. Also, make sure the breather vent is clear. After assembly, give it an hour or so before filling it up.
Old Nov 11, 2008 | 11:13 AM
SFeintuch's Avatar
SFeintuch
The silver greasy coating on your drain plug is metal. That plug is a magnet. Sounds like you have a problem,Either a new ring and pinion or bearings to solve it, Take it back to your dealer
Old Nov 11, 2008 | 01:20 PM
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by Skullonarm
There is a better way. It's called a gasket.
Actually the gasket that comes in the master rebuild kit doesn't offer a very good seal. When I regeared mine the fella used the gasket. Two days later I was back in the shop having him put black RTV on it. As it leaked somethin' fierce.
There's a nice little channel all the way around that diff cover for the RTV. I agree, it sounds as if either the guy didn't use enough or didn't allow it to skin over.
I've not had any more issues with my 08 diff cover.
Old Nov 11, 2008 | 03:52 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Monsta,
I actually thought about asking the shop to do it this way since they were having issues getting a good seal...especially since the '08 cover has that groove cut into the under side which would act like an O-ring after the RTV set up...
1) Remove cover and drain
2) Clean out housing very good and let drip over night (I was in no rush for the Ex)
3) Clean housing and cover of old RTV with proper solvent(s)
4) RTV the cover and make sure all bolt holes are covered properly
5) Install cover and torque to 1/8 to 1/4 bolt torque and let sit over night
6) Torque bolts rest of the way (24 ft-lbs)
7) Fill housing with 75W-140 Synthetic fluid
If I have to do this again...I believe this is how I will do it. This way the RTV will set up overnight...then I can compress it further filling any possible voids when I torque the bolts to 24 ft-lbs...
I haven't checked mine since I snugged the bolt...maybe tonight...
Just a thought...
Joe.
Old Nov 12, 2008 | 01:16 AM
SUV KING's Avatar
SUV KING
Try using Permatex Right Stuff gasket maker. Don't need to wait for it to cure, just squeeze, torque & refill. I've used it on diff covers, valve covers, thermostat housings, motor & tranny oil pans and water pumps. Haven't had a leak yet. (knock on wood)
Old Nov 12, 2008 | 06:20 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Well I checked the cover last night. I snugger her up on Sunday afternoon...and so far so good...NO MORE LEAK...I'll continue to watch it but hopefully this fixed her.
Thanks again for all the advice...rep points all around!
Joe.
robert_l_ross
Sep 1, 2023 03:17 PM
Buck268
Sep 24, 2016 11:00 PM
Jolly Roger Joe
Sep 18, 2016 11:07 AM
Shake-N-Bake
35
Dec 20, 2015 07:48 PM
genscripter
19
May 10, 2015 03:57 PM
