stuck throttle?
Old Nov 8, 2008 | 10:39 AM
alllincolnallthetime's Avatar
stuck throttle?
86 f-350 with 351. throttle not stuck, butterflys seem to be closed in carb but engine revs uncontrollably. any ideas?
Old Nov 8, 2008 | 11:39 AM
Opossum's Avatar
Opossum
Vacuum Leak!
Something has come loose. You say this is a carberated truck. That makes thing simpler.
Is the carb bolted down tight, they do come loose, is it the holley, they break?
Plug all the vacuum lines one at a time until the engine slows down.
Old Nov 8, 2008 | 12:00 PM
52 F3's Avatar
52 F3
Does this have a 4V carb. Could be the secondarys stuck open.
Old Nov 8, 2008 | 03:01 PM
figured it out. screw heads broke off on the primary causing the butterfly to stick open. not to search for the screw heads before they go someplace i don't want them
Old Nov 8, 2008 | 03:06 PM
Opossum's Avatar
Opossum
Ouch! Those screws are swedged after they are installed. This makes fixing the carb rather tricky I recommend you find those heads then take the carb to a good carb shop so the shaft and those bolts can be repaired properly.
Old Nov 8, 2008 | 03:14 PM
thinking they have been gone for awhile. I believe theyt are a brass screw thats why my engine isn't junk yet
Old Nov 8, 2008 | 03:20 PM
Opossum's Avatar
Opossum
True True, very lucky but pull your plugs and take a look just to be sure.
Old Nov 8, 2008 | 06:39 PM
jimbo beam's Avatar
jimbo beam
The exact same thing happened on my 86 F150, 351 4V. Started it one day and it revved to the moon, shut it off and looked every thing over and it all looked fine. Pulled the carb off and one of the secondary butterflies fell out and landed on the ground.
The screws are copper, they were more then likely pulverized within a second or so of going in the engine, if its still running fine I wouldnt let it bother me.
I ended up rebuilding my engine about 40,000 miles later, for other reasons, and never did see any sign of the screws.
Old Nov 8, 2008 | 11:22 PM
glad to hear that, it makes me feel 100% better
Old Nov 9, 2008 | 01:56 AM
jimbo beam's Avatar
jimbo beam
Hey no problem man.
If you ever take a screwdriver to one of them screws you'll see how they smush if you don't turn them just right. They're really soft, not really any chance that they could do anything to bad to an engine. Happened to the 302 in a buddy of mines Mustang as well. That was a few years and it still runs fine, hes never had it apart.
I ended up fixing my carb using a couple screws I robbed of the base of an old holly I had in my garage. I just drilled what was left of the broken screws out, stuck the "used" in and smushed the bottom of them a little so they wouldn't work their way back out. The carb worked just fine for another 40,000 miles or so until I replaced it with a better one when I rebuilt the engine.
77300i6
1997 - 2003 F150
Jul 4, 2011 09:21 PM
beagledog
Feb 27, 2008 09:35 PM
beagledog
Feb 26, 2008 11:25 AM
yosemite
1978 - 1996 Big Bronco
Dec 21, 2002 06:32 PM
FirstF150
Feb 11, 2002 08:45 PM
