1978 - 1996 Big Bronco
taking off throttle body....?
Old Dec 21, 2002 | 01:03 PM
yosemite's Avatar
yosemite
I'm trying to replace my TPS on a 1988 351 EFI. I've never done this and I'm stuck. How do you disconnect the 3 cables going to the throttle plate(ie: throttle, cruise?, and transmission??) ? I have to do this to totally take off the throttle body. I don't want to force them b/c they are made of plastic.
Brian
Old Dec 21, 2002 | 01:30 PM
steve83's Avatar
steve83
The cruise cable snaps onto the throttle cable. If there's a retainer holding it to the throttle-body bracket, remove that first and then swing the back of the cruise cable away from the throttle cable to disengage the clip, then move it toward the end of the throttle cable to disengage the pin in the end.
The throttle cable & TV cable (for the AOD transmission only) each snap onto a ball stud, so they just pop straight up.
Old Dec 21, 2002 | 02:08 PM
yosemite's Avatar
yosemite
Thanks Steve. I got it. One more thing. I'll have to take off 2 coolant hoses, one on top and one on bottom. Will i need to drain the coolant or will it not spill?
Brian
Old Dec 21, 2002 | 03:00 PM
steve83's Avatar
steve83
It may spill a little, but it's so high on the engine that very little will drain, so just be prepared to plug them with a couple of appropriately-sized bolts. You might even jam them onto the throttle-body studs...
Old Dec 21, 2002 | 06:32 PM
AlM's Avatar
AlM
1saxman
2004 - 2008 F150
Jul 18, 2014 04:05 PM
Madesen
Feb 6, 2010 09:59 AM
smus9917
Feb 22, 2009 09:16 AM
xKirkx
16
May 12, 2005 11:55 AM
02FX4Dude
Nov 12, 2004 04:46 PM
