Stud Question
Old Nov 8, 2008 | 04:46 AM
dirtleg's Avatar
dirtleg
Stud Question
Hello all. I just got my 6.0 a week ago w 70,000 miles on it. I bought it in spite of the knowledge that headgaskets are a time bomb on these motors.
My question is would it be possible to replace the head bolts with studs without removing the heads? My gut tells me no but I am certainly not a guru in these waters. My goal is obviously to prevent the headgaskets from blowing in the first place.
My concerns would be that if 1 bolt were replaced at a time the heads would crack due to uneven torque stresses. Or if all the bolts were untorqued the headgaskets would somehow lose their seal in the process.
Sorry if this is a dumb question but sometimes you just have to ask.
Old Nov 8, 2008 | 05:36 AM
ljutic ss's Avatar
ljutic ss
Why don't you just enjoy the truck and not worry about head gasket failure. There are hundreds of thousands of 6.0 powered vehicles that didn't have head gasket leaks.
Old Nov 8, 2008 | 07:14 AM
dirtleg's Avatar
dirtleg
Point taken. Doesn't answer the question however.
Old Nov 8, 2008 | 09:00 AM
Dustball8504's Avatar
Dustball8504
You'll find on here that it is STRONGLY advised for you to take the heads off and have new gaskets put in while you're at it. Thats the best way to do it and make sure it doesn't need to be redone. Its always best to do it once and do it right.
Old Nov 8, 2008 | 11:35 AM
riggz's Avatar
riggz
There are also hundreds of thousands of 6.0 powered vehicles that have had head gasket failures. Why wait until it's a problem if you can prevent it?
The heads should be removed to install the studs. You can do it without lifting the cab but it takes a lot of patience and time from what I've read. Someone posted a semi-how-to here a short while ago.
Old Nov 8, 2008 | 12:08 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Just to add to the discussion, if I was going to go through the cost and effort of installing studs, I'd also do an EGR delete at the same time. That way you'd eliminate three of the main reliability problems with the 6.0 (HG issues, EGR cooler issues, EGR valve issues) at one time.
Old Nov 8, 2008 | 12:35 PM
Dustball8504
Agreed, the only reason mine didn't get done like that was because they were done under warranty. EGR delete is high on my list though!
Old Nov 8, 2008 | 12:51 PM
cartmanea's Avatar
cartmanea
I've run some pretty hot tunes without getting any puking or headgasket problems. I would leave it alone until you either have a problem or you have the cab off doing other work. Yes, some people have done headstuds without pulling the heads or cab, but it is generally advised against. It is very hard to get the torque wrench on the rear bolts doing it that way and you chance not torquing everything evenly. I'm waiting until I have a reason to pull the cab, then I have a list of stuff to do, including heatstuds.
Old Nov 8, 2008 | 01:52 PM
hangon2me's Avatar
hangon2me
Has anyone blown head gaskets after the EGR blocked off? (stock or tuned)? Just curious because, I believe that most Head Gasket problems are caused from the EGR cooler and/or EGR valve failures.
Old Nov 8, 2008 | 02:00 PM
dcaddi2's Avatar
dcaddi2
I blown my head gaskets a while ago. When i pulled my engine apart, checked the EGR cooler and valve, and they were in perfect working order.
So it's true that some - maybe most - of the head gasket problems are caused by EGR , but not all of them...
Old Nov 8, 2008 | 02:17 PM
cartmanea's Avatar
cartmanea
I'd say most of the head gasket problems are due to there not being enough bolts per cylinder and Ford used TTY bolts instead of studs to begin with. A lot of people with EGR deleted still have head gasket problems.
Old Nov 8, 2008 | 02:19 PM
hangon2me's Avatar
hangon2me
Talking to Diesel Mechanics they all tell my that the right head always blows first, I am thinking that the EGR cooler is dumping extra heat into the right head causing it to warp first.
Old Nov 8, 2008 | 02:21 PM
dcaddi2's Avatar
dcaddi2
"most of the head gasket problems are due to there not being enough bolts per cylinder and Ford used TTY bolts instead of studs to begin with."
very well said cartmanea!
Old Nov 8, 2008 | 02:30 PM
dcaddi2's Avatar
dcaddi2
The EGR cooler dumps the hot/cooled exhaust in to the right side of the intake manifold, but through the EGR valve - it's pretty much evenly heats both sides.
IMO it isn't about warping to begin with. It's more like high boost, really weak bolts. If you blow your head gasket or gaskets, and you catch it right when it happens, pull the heads, they are not necessarily warped. The head bolts are the cause of it.
I don't know if it's true that the pass side is the first-one, I've had both sides gone...
Old Nov 8, 2008 | 08:37 PM
dirtleg's Avatar
dirtleg
Thanks for the info. I pretty much figured it would require removing the top end but for whatever reason didn't want to accept it without more input.
Well with this new info it seems I'll just run it till the warrenty expires prior to doing the studs. I do a fair amount of towing in the 8k to 14k range and am concerned that I may get stuck out on the road somewhere. That would be bad.
As far as the EGR delete I am all for it as long as I can still pass the yearly state inspection. I'll have to do some research on whether or not this is an inspected item.
