Weak blower motor
Old Nov 7, 2008 | 08:30 PM
bigcountry1009's Avatar
bigcountry1009
Weak blower motor
My blower motor in my 84 is terribly weak. Not sure if any of these trucks had real strong blowers. Is there a way to make it stronger. Give it more current? Maybe install one from later model truck?
Old Nov 8, 2008 | 04:43 AM
srercrcr's Avatar
srercrcr
Maybe there's leaves etc blocking the air.
Old Nov 8, 2008 | 09:58 AM
GLR's Avatar
GLR
I pulled my 86 out, getting rid of the leaves helped a lot.
Old Nov 8, 2008 | 11:34 AM
bashby's Avatar
bashby
I noticed the other day my 86 has no screen under the cowl to keep leaves out. I plan on installing one
Old Nov 9, 2008 | 07:34 PM
bigcountry1009
Never thought about that. Could be a mouse nest in there for all I know.
Old Nov 9, 2008 | 07:41 PM
bashby's Avatar
bashby
could be eletrical also, Does it sound like the fans spinning fast enough?
Old Nov 9, 2008 | 07:45 PM
bigcountry1009
Well, it puts out air. Doesn't sound like anything is holding it back. And all the speeds work. It just doesn't put out the amount of air as a newer model vehicle. I don't have another truck of similar year to compare it to. I'm mostly concerned about the A/C. I'm thinking if I get a larger volumn of air to move through the cab it would "feel" better, know what I mean? It's like on my dad's late model Dodge, I think you could fill balloons with the amount of air that fan moves.
Old Nov 9, 2008 | 08:35 PM
Franklin2's Avatar
Franklin2
My 80 was like that, and by digging all the pencils and and junk out beneath the windshield, it helped the defrost a lot. Then when I was doing something else, I took the A/C box off in the engine compartment, and found more junk in the duct, and I cleaned the A/C evaporator core fins, and after that, the heater would run me out of the truck.
So it's safe to say, there is not a design problem with the airflow or the heat in these trucks.
Old Nov 10, 2008 | 12:31 AM
The_SnowMan710's Avatar
The_SnowMan710
ya, i had terrible air flow in my 81, so after disassembly i found i had an enormous rats nest in my a/c evaporator and after cleaning all that crap out, i have great flow! now if i could just get the right thermostat in there, i could maybe have a warm drive for a change...
Old Nov 10, 2008 | 04:16 AM
srercrcr's Avatar
srercrcr
I read these guys with 165 stats...just takes that much longer to get good heat on a cold NE morning.
Old Nov 10, 2008 | 04:46 PM
The_SnowMan710
ya, kinda like today. i got a 180 stat in there now and it blows somewhat warm air, so i think a piece of cardboard in front of the radiator will take care of the rest of it.
Old Nov 10, 2008 | 06:35 PM
Holmesuser01's Avatar
Holmesuser01
Most of our trucks call for a 195 degree stat. Why not just run that?
Check out the fan and look for crud in there. These trucks have decent blower systems.
Old Nov 10, 2008 | 07:34 PM
The_SnowMan710
i looked everything over on my truck, but in the summer time, when i use it to pull w/, it would have a little problem w/ overheating. put me in a 160 degree and problem solved, ran right at operating temp. now that it's cold outside, i can't get the stinker to warm up for nothing or nobody! everything is in working order, it's just that the engine is pretty tired. i plan on running stock 195 when i overhaul her and put in an actual guage w/ numbers on it so i can see exactly what it's doing...
Old Nov 13, 2008 | 07:53 PM
bigcountry1009
I imagine it's time to clean out the ducts and blower housing anyway. Warming up in winter with a lower than stock thermostat can be a problem. I'm gonna put a bigger radiator in mine with the 195 thermostat, that way it will warm up fine, but have a larger capacity in summer time to be able handle the heat.
Old Nov 14, 2008 | 12:24 AM
The_SnowMan710
that's a good idea actually. any idea wat a larger than stock radiator costs?
toolsinbox
Oct 8, 2015 01:36 PM
brandonellisce
2009 - 2014 F150
Jun 20, 2015 11:46 PM
brandonellisce
2009 - 2014 F150
Jun 19, 2015 05:58 PM
alchemist1
Mar 1, 2014 08:13 AM
jprix
Dec 3, 2013 03:08 PM
