Cleaning bearings before packing
Old Nov 7, 2008 | 05:54 PM
Kep4's Avatar
Kep4
Jäger
It's time to grease the bearing on my Toyhauler. I've got some Lucas Red 'n' Tacky grease and the time. So what is best for cleaning the old grease out of the bearings?
Should I use mineral oil, kerosene, brake cleaner, Diesel fuel, or ????
Old Nov 7, 2008 | 09:01 PM
Steina's Avatar
Steina
CO River Rat
I use plain ol' alcohol; cheap and does the trick. Whatever you do, DON'T spin the bearings with compressed air to dry them, as that can cause problems.
Steve
Old Nov 8, 2008 | 11:38 AM
Kep4's Avatar
Kep4
Jäger
Alcohol... sounds good! It will clean and then evaporate quickly leaving no residue. Should I use Tequila or Vodka?!?!
Thanks for the tip Steve.
Old Nov 8, 2008 | 05:53 PM
grafekie's Avatar
grafekie
Tequila for you, Vodka or isopropol for the bearings :P
Old Nov 8, 2008 | 07:01 PM
rbaker6336's Avatar
rbaker6336
use whatever solvent you have handy, gas ,diesel ,paint thinner,really don't matter
Old Nov 8, 2008 | 08:20 PM
Steina's Avatar
Steina
CO River Rat
I'd be a little hesitant to use gasoline or paint thinner if the job's being done in a garage with a gas water heater.
Steve
Old Nov 8, 2008 | 09:09 PM
rbaker6336's Avatar
rbaker6336
paint thinner is low grade mineral spirits less flamable than alcohol
Old Nov 9, 2008 | 09:06 AM
Steina's Avatar
Steina
CO River Rat
Ray -
This is just one quote from the Web:
"The fumes from paint thinner are not only harmful if inhaled; they are also flammable. In order for paint thinner to be used safely, it should always be used in a well-ventilated area away from any source of open flame. Paint thinner fumes should never be inhaled, especially in high concentrations. Make sure your work area is well ventilated by opening a window or running an exhaust fan, and wear a face mask to reduce the inhalation of fumes."
Steve
Old Nov 9, 2008 | 11:34 AM
rbaker6336's Avatar
rbaker6336
well wash the with soap and water then,but that will probly be poison to somebody
I don't buy in to all that crap
Old Nov 9, 2008 | 03:31 PM
ranger56528's Avatar
ranger56528
Ive allwaysed used parts cleaner/stenisol then blow them out with air then use Brk cleaner to make sure they are clean and dry....I cleaned the hubs out with high pressure soap and water then finished with brk clean and a rag.Thats how the Rep from Utillity Trailer Mfg showed us.
But what do I know. I do the same with my boat trailers and utility trailers...
Old Nov 9, 2008 | 06:39 PM
MisterCMK's Avatar
MisterCMK
I wipe off all the grease that I can and then leave them in the parts cleaner for a while. After the parts cleaner I hit them with some brake cleaner.
Old Nov 21, 2008 | 04:17 PM
97squarebody's Avatar
97squarebody
My understanding is that if they are clean from contamination when you remove them you should actually not wash them in anything. Just use high quality clean grease and start packing them. Keep pushing in the new grease until no more of the old is coming out. My understanding is that many bearings are lost to people "washing" contamination into the bearing. It is what I was taught, it has served me well.
Old Nov 21, 2008 | 05:56 PM
avator's Avatar
avator
I've repacked hundreds of bearings - and use compressed air to dry them with no damage or problems.
just saying........
Old Nov 21, 2008 | 08:30 PM
Ford_Six's Avatar
Ford_Six
The problem with just re-greasing bearings is that there are several types of grease out there, and some types react. For a crash course on grease:
Grease starts as oil, and is thickened with the addition of soap. This soap base varies between manufacturers, and some types react, breaking down, and dropping the liquid oil out of suspension.
I have had bad luck using paint thinner, that was all I had available on the side of the road. Had a brake come apart and lock, and managed to drop the bearing in the dirt taking the hub off. Washed it with paint thinner in the dog's water dish, the dog was not happy.
Old Nov 22, 2008 | 09:00 AM
Steina's Avatar
Steina
CO River Rat
You can DRY 'em with air, just don't SPIN 'em.
Steve
