winter oil question
Old Nov 7, 2008 | 12:48 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
winter oil question
I am going to do an oil change, my first with this truck, and I wanted to get some 10w-30 for winter, in Vermont the temps in the winter average in the 20's F with some spells at -10 to -15F. My favorite parts store only has 15w-40 for diesels. He said that is what most guys use that he knows of. So, is the 15w-40 ok? thanks.
Old Nov 7, 2008 | 01:06 PM
Neal 97 250's Avatar
Neal 97 250
You should be able to find 5w-40 somewhere
Old Nov 7, 2008 | 05:28 PM
73strokin's Avatar
73strokin
I run Rotella 10w30 in the winter months for easier cranking. Most places don't sell it but I've found it at NAPA, and once in a while I see it around various other stores.
Old Nov 7, 2008 | 05:35 PM
952X4's Avatar
952X4
X2 what 73strokin said. Here in Wisconsin it gets mighty cold too, I run Rotella T 10w30 in the winter time as well. I've found it at NAPA and Autozone.
Old Nov 7, 2008 | 05:53 PM
Alaskan 350's Avatar
Alaskan 350
I run 15w40 all yeay long In In tempsas cold as -40 the starter has no trouble turning the engine over.
Old Nov 7, 2008 | 05:58 PM
scatgo's Avatar
scatgo
Rotella synthetic is 5w-40 and I think only the synthetic is 5w-40. Most places that sell Rotella seem to have it like NAPA
WALJON's Avatar
WALJON
I use 0/40 in those temps Alaskan ,My truck wouldn,t even try to start in -40 temps with 15/40 unless it was plugged in.
Old Nov 7, 2008 | 07:03 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
I'll check with NAPA to see if they have the 10w-30. If not I will go with the 15w-40.
Old Nov 7, 2008 | 07:22 PM
tjbeggs's Avatar
tjbeggs
Walmart normal has 5W40.
Old Nov 7, 2008 | 07:44 PM
BlueMule's Avatar
BlueMule
Tractor Supply Company also sells the 5W40 Rotella.
Old Nov 8, 2008 | 08:13 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Tractor Supply does carry it, I think it was like $25 or 26 a gallon for the 5w-40 and around $50 for 5 gallons of 15w40 rotella.
The truck is not my daily driver so I was kind of leaning away from the synthetics for now, but it would probably be worth it just to make it easier to start in the winter.
I will have to check the local wally world to see what they have also.
Old Nov 8, 2008 | 09:41 AM
c00nhunterjoe's Avatar
c00nhunterjoe
and your local ford dealer has motorcraft 10w30 diesel oil as well
Old Nov 8, 2008 | 10:04 AM
scatgo's Avatar
scatgo
Now for the big question. What dose oil weight have to do with starting in cold weather? I just dont see it. I know thats the way it is but why? What does it have to do with combustion? If the engine is getting fuel and the glow plugs are working and the engin is turning over it should start. I just dont see how thinner oil makes a difference.
Old Nov 8, 2008 | 10:48 AM
WALJON's Avatar
WALJON
Thinner oil at start up will help turn over better the thicker oil makes it turn over slow and run rough even setting the check engine light sure you can run 15/40 all winter but it takes that much longer to warm up and oil temps are important for efficientsy
farmert's Avatar
farmert
The thinner oil lets the starter spin the engine over easier and faster when the temps are cold, thus making it start with less cranking.
