How Flexible- DP Tuner?
Old Nov 7, 2008 | 09:44 AM
StampedePSD's Avatar
StampedePSD
Is the tuner programming flexible enough to combine performance, heavy towing and some economy with safety in one tune?
I am a set it and forget it kinda driver? I like performance when I am empty and safety and power when towing.
Thanks,
Lusty
Old Nov 7, 2008 | 09:59 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Lusty. You will have more then one tune with the DP. You can have 16 different tunes if you want. Its a push of a button to change from one tune to another. Look at my sig and you will see all the tunes I have on my DP. I can switch to which ever one I want while driving down the road. DP-TUNER
Old Nov 7, 2008 | 10:00 AM
That_Guy's Avatar
That_Guy
Thanks,
Lusty
Depends on what you tow, and how much power you want to have while empty. I know people that just use the 40 tow setting all the time.
Old Nov 7, 2008 | 10:03 AM
That_Guy's Avatar
That_Guy
Rick has a point, you can change them in about1/2 a sec...
Old Nov 7, 2008 | 11:11 AM
StampedePSD
That is great. I am learning all the time. I have looked on DP's page, but asking others gets you further. I tow 20k lbs once per week about 40 miles. It's not flat, so the long hills are what I am trying to be careful with. I like the power of the Superchips set all the way up, but I don't think the truck sounds like it runs as smooth. Shift on the fly would bge awesome. If you set the DP at 80, what's the torque and can you tow that much in this setting? EGT's.
Thanks alot for the help and advice.
Lusty
Old Nov 7, 2008 | 11:22 AM
willeo6709's Avatar
willeo6709
Your best bet is a call in to DP. My experience with DP started last night. Basically there are econo tunes and tow tunes...econo tunes have lower rpm shift points and different boost curves. The tow tunes downshift sooner and hold gears longer. I'd say as long as your egt temps are reasonable you can tow in any tune you want. I think the recomended tune for towing over 13k is the 20HP tow. There is a 60HP tow... not sure on the 80 HP, I'd have to look at his site. Call them up and talk over your needs, they have your tune....
Old Nov 7, 2008 | 11:31 AM
miller_feed
You answered your own question. Depends on the EGT's. I ran the superchip for 4 years, but I changed the tuneing depending on what I was towing. The superchip in the performance setting could hurt your trans. Have you ever had your O/D button light flash on you.
Get a couple towing tunes. The best thing to do is to call Jody and he will answer all your questions. He will advise you what would best for your truck.
Old Nov 7, 2008 | 11:44 AM
dsquared's Avatar
dsquared
Every one of these guys is steering you right!!
When I got mine, I was debating over the 60 tow, or 60 Altitude tow. 2 minutes on the phone with Jody, and he explained it clearly and concisely.
Old Nov 7, 2008 | 11:52 AM
Old and Busted's Avatar
Old and Busted
Just starting to think about a tuner. How do they work with a manual transmission? My 350 has a 6 speed.
Old Nov 7, 2008 | 11:56 AM
scottm1's Avatar
scottm1
Thanks Stampede and everyone who answered his questions. I was wondering the same thing, but just hadn't had the time to ask those same questions yet.
Old Nov 7, 2008 | 12:58 PM
miller_feed
Transmission don't make a difference. The DP-TUNER sure will.
Give Jody a call. He and Diane are sponsors of our 7.3 forum.
Old Nov 7, 2008 | 01:42 PM
StampedePSD
Will Do!
Thanks for the advice. Sounds like what they offer is specific to you and how you use your rig. So a pat answer(what i thought I needed) just won't fit.
Lusty
Old Nov 7, 2008 | 01:43 PM
Pocket's Avatar
Pocket
As far as "flexibility" of a tune, that does depend on mods that are on the truck. Certain injector/turbo combinations, big oil, and other factors will play a role into how the truck behaves and how the EGT's climb when using various settings.
Also it is easier to control EGT's with a manual than it is an automatic.
Old Nov 7, 2008 | 01:49 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Nah....just downshift to 3rd and hold her at 3200.
Old Nov 7, 2008 | 03:01 PM
Izzy351's Avatar
Izzy351
Looks like you have a good trans already -- do you have a bigger cooler on it?? Pulling that heavy would require it, I would think.
I'd say ditch the Banks/SC stuff and go with the custom tuning. You can never go wrong with that option...
