92-93 engine swap
Old Nov 7, 2008 | 08:37 AM
stsscott's Avatar
stsscott
92-93 engine swap
Me AGAIN!!!
So if I gather all the info y'all gave me so far for putting a 93 Bronco 5.8L automatic into a 92 F150 5.0 5 speed............I have to keep the old intake, put a new flywheel on the 5.8, keep the 92 computer, keep the 93 exhaust manifolds, tinker with the exhaust somehow (not sure about this yet)
You agree with me on this???
Thanks for all your help!
Scott
anybody need any 93 Bronco parts??
Old Nov 7, 2008 | 08:46 AM
Conanski's Avatar
Conanski
You need the complete 93 5.8 motor.. everything from the oilpan to the throttlebody, none of the 5.0 parts fit the 5.8 motor.
You need the 5.8 manifolds and Y-pipe if it's in good condition.
You need a 28oz balance flywheel if you are keeping the manual tranny.
You need a 5.8 computer for a non computer controlled tranny, what trany is in the Bronco?
Old Nov 7, 2008 | 09:05 AM
stsscott's Avatar
stsscott
not sure, i will check later
Old Nov 7, 2008 | 09:11 AM
pfogle's Avatar
pfogle
In '93 the only automatic transmission available in a bronco was the E4OD.
Old Nov 7, 2008 | 09:32 AM
stsscott's Avatar
stsscott
Well then that settles it, that must be the one that i have
Old Nov 7, 2008 | 09:33 AM
stsscott's Avatar
stsscott
did you see the last reply about the only tranny bronco's had? what does this mean to me?
Old Nov 7, 2008 | 09:36 AM
Conanski's Avatar
Conanski
There have been people here that had trucks as new as '95 with an AOD tranny... but this was never offered behind the 5.8 to my knowledge. It is possible the Bronco has a C6, but if it has OD then it's most likely an E4OD. The tranny code on the door pillar will tell you for sure.
Old Nov 7, 2008 | 01:24 PM
pfogle's Avatar
pfogle
This means that you're options for an automatic transmission behind a 351w in a '93 bronco is an E4OD. To my knowledge they did not use the C6 in the bronco after about 1990.
Old Nov 7, 2008 | 06:11 PM
stsscott's Avatar
stsscott
tranny identification
Any other place I can look for numbers for what tranny I have in the Bronco....there's nothing on the door pillar
Old Nov 8, 2008 | 09:57 AM
Conanski's Avatar
Conanski
First figure out of it has OD or not.. look at the shift indicator. Does it have an OD switch on the dash or the shifter arm? Are there any electrical connections on the tranny? What does the tranny look like? See these items..
https://www.ford-trucks.com/article/...ers_Guide.html
Old Nov 9, 2008 | 01:57 PM
stsscott's Avatar
stsscott
tranny
OK:
There is no OD on the shifter/dash ....anywhere! The tranny has an embossed Ford logo on it and says Metric and there is a big bump in the middle of the pan, and no electrical connections on it.
Old Nov 9, 2008 | 05:31 PM
Conanski's Avatar
Conanski
What is the shift indicator sequence?
What does the pan look like from this link... Ford C4 and C6 Transmissions
Old Nov 10, 2008 | 06:45 AM
stsscott's Avatar
stsscott
tranny
Definitely looks like the bottom one, and like this says, has a big rubber plug in the bottom of the bell"
"AODE/4R70W go from 92 to present. It’s pan is similar to the AOD. These trannies have a large neutral switch (sometimes called a MLPS) mounted to the manual linkage and has a hole covered by a rubber plug on the bellhousing’s bottom. 4x4 truck pans (and 76+ model cars and 2wd trucks) are dropped near the center. "
MikeTheBasedGod
Apr 3, 2017 08:47 PM
Spktyr
Sep 22, 2016 10:55 AM
f150truckguy
May 29, 2014 12:27 AM
Blue2
Jul 8, 2004 01:29 PM
AbadDriver
New Member Introductions
Apr 14, 2003 12:48 AM
50, 58, 92, 93, swap
