Sponsored by: Real Truck
wiring lights
Old Nov 6, 2008 | 02:44 PM
stroker870's Avatar
stroker870
wiring lights
I'm wanting to put those orange lights to shine on my steps and i was wondering what i fuse i need to wire them into so when i hit the unlock button on my key less entry they light up?
Old Nov 6, 2008 | 04:16 PM
dew the thunder's Avatar
dew the thunder
I know someone will correct me if I'm wrong but there is a harness underneath the rears of the front fenders (I have them on my truck, you may want to check yours) that I always thought was an entry lighting harness. If that's true you could probably use those to wire in some lights.
Old Nov 6, 2008 | 05:03 PM
riggz's Avatar
riggz
It would help to know what year/engine type your truck was.
Old Nov 7, 2008 | 10:27 AM
stroker870's Avatar
stroker870
2002 ford F250 7.3. how do i get my info to show up in the bottom of my post im new to this still
Old Nov 7, 2008 | 11:24 AM
dew the thunder
IIRC when you hit 25 posts the signature option becomes available in your "User CP"
Old Nov 7, 2008 | 11:33 AM
ReAX's Avatar
ReAX
I know the 2000 Excursions had that harness, but I don't believe my 2002 F250 does. The real problem your going to run into, is the dome light circuit may not turn on lights until you open the door. If you have an aftermarket alarm there may be an output for courtesy lights that will burn for several seconds after you press a button.
Old Nov 7, 2008 | 12:42 PM
dew the thunder
Maybe I'll have to grab a neon bar or something and try hookin it to that harness in the fender. I know my dome light turns on with the unlock button on the remote.
Old Nov 7, 2008 | 04:48 PM
Bernie Lomax's Avatar
Bernie Lomax
You just need to tap into the parking light wire. I forget which it is, I think purple/white ? I can't be sure.
Old Nov 7, 2008 | 05:40 PM
ReAX's Avatar
ReAX
The parking light wire will only illuminate the lamps when the parking lights are on or if the alarm flashes them. I believe he's looking for courtesy lights. The parking light wire should be brown at the switch.
Old Nov 8, 2008 | 12:25 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
He said he wants them to light up when he hits the unlock button which would be the parking light circuit, if he want courtesy lights he needs to say that. So to answer his question it would be the parking light circuit as mentioned earlier.
Old Nov 8, 2008 | 01:44 AM
ReAX's Avatar
ReAX
Don't the parking lights flash when you hit the lock/unlock? For steady you would have to add a timer relay to the parking lights circuit.
Old Nov 8, 2008 | 02:33 AM
Steve_250's Avatar
Steve_250
Nope.
He wants them to stay on long enough for someone to get in, not just flash like the parking lights.
Find the circuit for the center dome light. It stays on for 25 seconds on entry/egress. I don't know where the timer is in that circuit though.
AndeyHall
Feb 20, 2018 08:03 PM
vwfreak
Nov 6, 2013 06:21 PM
z 97ford1
Nov 26, 2003 09:40 AM
91ExploXLT
Nov 9, 2003 11:13 AM
bossmanbef
All Things Towing
Apr 5, 2003 06:36 PM
