need hub help!
Old Nov 6, 2008 | 09:32 AM
jere925's Avatar
jere925
need hub help!
i own an 1989 f150 and I am converting from auto to manual warn hubs. I am looking in the chilton's guide and the auto and manual dana axles have different setups as far as locknuts and the like is concerned. My question is, when converting to manual hubs do I need to convert the whole setup to look like the manual one, or do I keep the auto axle setup and just swap in the manual hub. The manual axle picture does not show any locknuts and does not show a hub. Thanks for any advice.
Old Nov 6, 2008 | 11:52 AM
andym's Avatar
andym
You can keep the locknuts you have and just use the manual hubs. There may be a conversion kit that you need, this depends on whether you have 3-screw or 5-screw automatic hubs.
