Bronco II Ford Bronco II
87 Start-up issues
Old Nov 5, 2008 | 06:15 PM
Rockybronco's Avatar
Rockybronco
87 Start-up issues
Alright, I am rather new to all of this so here is goes.
I have an 87 Bronco II. Love it. I have began to have a problem when I start it up. No matter if it is cold or hot doesn't matter. When I crank the engine it starts right up every time. Thats when the problem begins. It sputters, dies, runs rough and will not stay running with out pressing the accelerator. I can normally keep it running but pushing the accelerator. Once it begins to warm up to keep it running I have held the accelerator with some pressure trying to keep it around 2500 rpms. Just will not stay there. Gets there... Sputters out and then catches itself back up for a brief moment then falls back to around 750 rpms. I am puzzled by this but it gets better. I can put it in drive and it runs perfect until i get to a stop light or have to stop and it will sometimes go back in the described above habit but not always. I have replaced the TPS and cleaned out and tested the IAC. Changed my plugs and plug wires. I don't think I have a check engine light on the vehicle not sure though so I can't pull a code off of that. I just don't know where to go next. Thanks for your help in advance.
Old Nov 5, 2008 | 09:09 PM
bronco2man's Avatar
bronco2man
sounds like the o2 sensor, replaced mine and it doesnt stall anymore
Old Nov 5, 2008 | 10:32 PM
mrshorty's Avatar
mrshorty
Ford didn't put a CEL in the '87's, so you have to pull codes to find out if the computer can see anything. That's the first thing I'd do.
AbandonedBronco
39
Dec 24, 2017 10:09 AM
mhofmann86
Sep 22, 2015 03:45 AM
rob7676
1997 - 2003 F150
Aug 26, 2015 04:24 PM
Critter183
Sep 8, 2007 01:32 PM
