Coolant Leak
Old Nov 5, 2008 | 12:26 PM
gomfrddy's Avatar
gomfrddy
Coolant Leak
I was replacinng my serpentine belt and I decided to remove the top radiator hose, when I started to try to disloge the hose from the block side I noticed coolant started to leak from where the t-stat sits. I replaced the t-stat and the gasket but it is still leaking. Any Ideas?
Old Nov 5, 2008 | 12:48 PM
Hussler's Avatar
Hussler
Most replace the entire neck when leaking. Just did my 203 stat and used old neck as it was still in good condition. First attempt resulted in a leak about the 10:00 position in your photo. Re did it but this time made sure everything was good and dry where the o-ring sits. Also used a little RTV to help hold the o-ring in place.
Old Nov 5, 2008 | 01:42 PM
maverick1701's Avatar
maverick1701
X2 most folks replace the neck... I just used some liquid gakset and it worked great
Old Nov 5, 2008 | 01:56 PM
Eric_F250's Avatar
Eric_F250
if the neck flange is flat, a new o-ring should be enough to ensure a good seal. if not, get a new neck. only 20 bucks.
to me, it seems like 3 bolts is not enough. a 4th would have allowed us to get more even pressure down on on the t-stat and o-ring.
Old Nov 5, 2008 | 03:37 PM
gomfrddy's Avatar
gomfrddy
thanks guys!!!!!!!
gomfrddy
24
Jun 6, 2011 09:12 PM
John SCB
Feb 22, 2010 04:08 AM
gomfrddy
Nov 7, 2007 06:39 PM
PSNut
Oct 12, 2006 11:16 AM
