Modular V10 (6.8l)
Exhaust Manifold Studs
Old Nov 5, 2008 | 11:30 AM
DaveandJennyP's Avatar
DaveandJennyP
I am going to replace my original studs here soon. I am not interested in headers so i wll check manifolds for flatness and machine if necessary.
Should I get replacement studs from FORD or just use high quality bolts when I reinstall?? If studs from FORD how much should I be expecting?
Thanks.
Old Nov 8, 2008 | 10:23 AM
69cj's Avatar
69cj
I would try grade 8 studs with anti-sieze.
Old Nov 9, 2008 | 10:00 PM
Jim Hughes's Avatar
Jim Hughes
Exhaust Studs
Hi,
Just checking on what people are paying for the exhaust studs. I have to replace all of them in my EX, only a couple of ones left that are not broke.
What has been the price for the job done at the shop?
Thanks for the help.
Jim
Old Nov 11, 2008 | 08:53 PM
landcruzr's Avatar
landcruzr
I'm having them all done on both sides- machine shop told me somewhere between 1000 and 1500 for the job- They are either going to pull the motor or remove the heads- not sure whats is going to be easier yet!!- Has anyone done this job before and willing to share info????
Old Nov 12, 2008 | 07:34 PM
boxcar1974's Avatar
boxcar1974
Ford now uses stainless studs. You can get to the studs through the wheel wells. You need to remove the fender liners and you will have good acess.
I replaced all the studs with stainless bolts when I installed my headers. You have to be very patient and be willing the walk away. A right angle drill will help getting into the tights places. It is a very labor intensive job. The cost to have it done will be high seeing alot can go wrong if the proper steps are not taken.
Old Nov 15, 2008 | 08:47 AM
EXMAN123's Avatar
EXMAN123
I had 3 bolts broken off. I took it to the local Ford dealership as I do not have the tools or the mechanical ability to do this type of job. It cost me $850.00 to do the complete job. They took out all of the bolts etc and put in a new gasket and buttoned her all up. GOOD AS NEW!!
EXMAN123....
frenchf250
Modular V10 (6.8l)
Jan 13, 2014 07:34 AM
balingwire
Exhaust Systems
Mar 25, 2009 11:36 AM
truckmonger1
1997 - 2003 F150
Oct 10, 2007 10:48 PM
wildboar12
1978 - 1996 Big Bronco
Nov 7, 2005 02:25 PM
Torque1st
Garage & Workshop
Dec 27, 2003 08:02 PM
