New motor ???
Old Nov 5, 2008 | 09:24 AM
black02eb's Avatar
black02eb
New motor ???
Hello all
I am swapping in a 04 Navi engine into my 02 Expedition this weekend. I have switched out the oil pan and other parts and it is just about ready to go. The motor has NO oil in it.
My question is , how do I get the oil pressure up when first cranking it without damaging anything?
Old Nov 5, 2008 | 10:05 AM
alloro's Avatar
alloro
I would just start it, but not rev it up until you see pressure. If you're not comfortable with that, simply disconnect the 2-wire connectors from each of the 8 COPs and then spin the starter for 30 seconds or so. After that, reconnect the COPs, then start the engine.
Old Nov 5, 2008 | 10:17 AM
black02eb's Avatar
black02eb
Thanks alot, I think I will disconnect the cops like you said.
Old Nov 5, 2008 | 10:23 AM
anfo's Avatar
anfo
wouldnt it be easier to pull the fuel pump fuse or block the line? some of those connectors are a pita to get to and 8 steps vs.1 always wins for me.
Old Nov 5, 2008 | 11:47 AM
black02eb's Avatar
black02eb
I think the cam or crank sensor would work too , right?
Old Nov 5, 2008 | 12:27 PM
alloro's Avatar
alloro
Don't see why not, basically anything to keep the ignition from firing while the starter is turning should work.
Old Nov 5, 2008 | 01:07 PM
black02eb's Avatar
black02eb
Perfect Thanks!
unhcp
Modular V8 (4.6L, 5.4L)
Oct 3, 2011 06:35 AM
GPL
Oct 4, 2010 11:24 PM
John with beastly 302
Oil & Lubrication
Mar 1, 2003 12:29 PM
Ford Truck Racer
Dec 5, 2002 10:57 PM
