2004 f150 headlight delay
Old Nov 5, 2008 | 07:02 AM
jtcsrvbi's Avatar
jtcsrvbi
Hello all thanks for looking at this... i think i posted in the wrong place before.
I use the auto headlights when I turn my truck of the lights stay on for about 5 min... is there a way to shorten this up??? less than a min would be great!!
thanks, john
Old Nov 5, 2008 | 07:21 AM
xjcamaro89's Avatar
xjcamaro89
Wow, 5 mins? Thats a long time. i installed the automatic headlight kit in my 04 and i thought the stayed on pretty long after i turn the truck off, maybe 2 mins. But 5 is pretty long.
Old Nov 5, 2008 | 10:04 AM
shorebird's Avatar
shorebird
From the owners manual for my '08
The autolamp system also keeps the
lights on for approximately
20 seconds or, on vehicles equipped
with a message center, you can
select a delay from 0–180 seconds,
after the ignition switch is turned to
OFF.
• To turn autolamps on, rotate the control counterclockwise to (illuminated lamp symbol) .
• To turn autolamps off, rotate the control clockwise to Circle.
If your vehicle is not equipped with a message center, then the auto
lamps can be programmed manually by:
1. Start with the ignition in OFF and the autolamps selected (illuminated lamp symbol).
2. Turn off the autolamps by turning the headlamp switch to circle.
3. Turn the ignition to ON.
4. Turn the ignition to OFF.
5. Select the autolamps by turning the headlamp switch to (illuminated lamp symbol).
Steps 2 through 5 must be performed within a 10 second period. At
this point, the headlamps and park lamps will turn on.
6. Deselect the autolamps after the desired autolamp delay time
(maximum of 3 minutes).
At this point, the headlamps and park lamps will turn off.
Old Nov 5, 2008 | 10:23 AM
xjcamaro89's Avatar
xjcamaro89
Oh, ya i forgot about that, give that a try.
Old Nov 5, 2008 | 12:25 PM
jtcsrvbi's Avatar
jtcsrvbi
thanks shorebird
that worked!!
Old Nov 5, 2008 | 03:38 PM
shorebird's Avatar
shorebird
Glad to hear it.
Old Jul 23, 2015 | 12:41 AM
MysticSeer's Avatar
MysticSeer
Thanks shorebird. Worked to set the delay! 2010 Mustang with added switch SW-6833 to give me the auto on/off feature. My car doesn't have fog lamps so I bought that switch rather than the one with the fog lamps switch too.
jimlin66
17
Dec 12, 2020 02:52 PM
bbdano
Dec 31, 2015 11:20 PM
cliffhanger228
Sep 2, 2015 04:59 AM
kenpep2
Electrical Systems/Wiring
Sep 28, 2003 07:37 PM
rogue69
Jun 6, 2003 04:18 PM
