Sponsored by: Real Truck
Pin Weight/GCVWR
Old Nov 4, 2008 | 06:08 PM
JohnG3's Avatar
JohnG3
Pin Weight/GCVWR
Ok, I have a 2004 F-250SD, Long bed, ExCab, V-10 with a 3:73 rear end and tow a 5th wheel trailer with a GVWR of 10400 pounds and a pin weight of 1500 pounds. The truck/trailer with me, wife, dog 3/4 tank of gas and 1/3 grey water tank weighed 17,030 pounds (30 pounds over the GCVWR listed in the owner's manual).
Now, I'm thinking of going to a 2005 or newer F250 SD configured almost the same way as this one. I heard that Ford upped the vehicle GGVWR to 9600 to 9800 pounds. I have not been able to find an owner's manual on line to check the tow tables for GCVWR and such. Anyone out there with a 2005 or newer have one that can post the GCVWR's for that truck?
I'm not against considering a F350 SD Crew Cab, SRW (maybe a diesel). I'm confident that rig will handle the trailer. Anyone know where I can find the towing chart for that combination to see what the highest (numerically lowest) gear ration I can get with a 20,000 pound GCVWR?
Thanks in advance.
John
Old Nov 4, 2008 | 06:45 PM
Mud Doc's Avatar
Mud Doc
You should definitely get an F350--should have about 11000 GVWR. You can only find 3.73/4.10/4.30 gears--most of the time it will be 3.73 on SRW, I think.
Try looking up Trailer Life archived tow ratings for whatever year you are interested in.
Trailer Life Magazine: America's Number One RV Magazine
Old Nov 4, 2008 | 07:59 PM
senix's Avatar
senix
check this out and see if it helps:http://www.motorcraftservice.com/vdi...g%20Manual.pdf
Don't think this is what you are looking for but you may find it on the motorcraft web site. will keep looking
Old Nov 4, 2008 | 08:32 PM
senix's Avatar
senix
check this outersonal injury.
Maximum GCWR - lb. (kg.)
Engine Rear axle
ratio
Manual
transmission
Automatic
transmission
F–250/F–350 Single Rear Wheel (SRW)
5.4L 3.73 15000 (6804) 16000 (7257)
4.10 17000 (7711) 18000 (8165)
6.8L 4.10 20000 (9072) 21000 (9525)
4.30 22000 (9979) 22500 (10206)
F–350 Dual Rear Wheel (DRW)
5.4L 3.73 15000 (6804) 16500 (7484)
4.10 17500 (7938) 18500 (8391)
6.8L 4.10 20500 (9299) 21500 (9752)
4.30 22500 (10206) 23000 (10433)
F–450/F–550
6.8L 4.10/4.30 26000 (11793) 26000 (11793)
Here is the link
http://www.motorcraftservice.com/pub.../05f23og3e.pdf
Old Nov 4, 2008 | 08:52 PM
JohnG3's Avatar
JohnG3
Thanks for the leads.
Old Nov 4, 2008 | 10:13 PM
powerstroke72's Avatar
powerstroke72
Here's the link to the Ford 2005 Towing guide. It should have the answers you're looking for:
https://www.fleet.ford.com/showroom/...05_default.asp
JohnG3
Jan 15, 2009 07:19 PM
banditsdaddy
Sep 24, 2007 08:43 AM
ibf250
Dec 16, 2003 01:18 PM
myotis
Modular V10 (6.8l)
25
Nov 11, 2003 12:29 PM
Dee C.
All Things Towing
May 10, 2003 10:56 AM
