Sponsored by: Real Truck
GCVWR Changes?
Old Sep 21, 2007 | 02:42 PM
banditsdaddy's Avatar
banditsdaddy
Question GCVWR Changes?
We pull a fifth wheel trailer with our 2006 F350 PS 4X4 SRW and GROSS COMBINED VEHICLE WEIGHT is a factor of concern. A Salesman told me today that there were recent changes to the F350 GCVWR dual rear wheel trucks with the 4:10 axle ratio. I looked at the Ford web site capacities and do not see any changes there. Anyone know of any increases that came out recently?
Any info would be appreciated.
Bill
Old Sep 21, 2007 | 02:56 PM
redford's Avatar
redford
FTE Leadership Emeritus
How can you tell when a salesman is lying?
His lips are moving.
The GCWR on your door sticker is your legal weight. It doesn't change.
He might be confused by the added capacity of the 2008 Super Duty trucks, but that has nothing to do with your truck.
Old Sep 21, 2007 | 03:10 PM
jetdoc's Avatar
jetdoc
I agree with Redford. These salesmen will tell you anything to move a unit. After doing alot of research here and RV.Net I decided against a large fiver that would be way over my GVCWR. After I weighed my truck I found out that the heaviest I could LEGALLY tow is 12000 lbs. That really narrowed the field down for us.
Old Sep 21, 2007 | 05:37 PM
Leader's Avatar
Leader
The GCVWR is a performance rating from the manufacturer not a *Legal* rating.
It is also NOT a safety rating. Towing or hauling ANYTHING is less safe then not in most cases.
How much you can gross is determinded by the state & how you register your truck.
Old Sep 21, 2007 | 05:42 PM
jetdoc's Avatar
jetdoc
Fair enough...I would find out if your insurance company will cover you if you're over their recommended limit.
Old Sep 21, 2007 | 06:27 PM
Leader's Avatar
Leader
Yes the insurance company ie required to cover you up to policy limits.
Old Sep 21, 2007 | 06:33 PM
banditsdaddy
I goofed, I was looking at a 2008 F350 DRW and the salesman said that Ford recently upped the GCVWR from 23500 lbs. to 24900 lbs. on the F350 dually. I was wondering if anyone else heard anything about this. I realize my '06 is rated at 23000 lbs. and that hasn't changed. The door tag only gives the GVWR of 11400 lbs. and the axle ratings.
Bill
Old Sep 22, 2007 | 05:29 PM
glsurratt's Avatar
glsurratt
Got to agree with Leader on this one. When I bought my Dodge in 1998, the brochure had a line in the fine print at the bottom of the weight charts that said "These numbers are based on providing acceptable performance with a vehicle properly equipped."
I guess the real question becomes "What is acceptable performance?" Does that mean that if it is acceptable to me to top a hill 10 mph slower, I can tote a bigger trailer?
Old Sep 22, 2007 | 05:50 PM
jetdoc's Avatar
jetdoc
Getting it rolling it the easy part, stopping it quick is where it gets dicey. I'm going to call my insurance agent Monday and ask him. I'll post my findings.
Old Sep 22, 2007 | 07:02 PM
redford's Avatar
redford
Why heck, even an F-150 can stop a 30,000 pound airplane!
Old Sep 22, 2007 | 10:08 PM
mudmaker's Avatar
mudmaker
there is a reason they have brakes on trailers!! The GCVW is not on the sticker because it nothing but a guess. you have to take the trailer you are pulling into account. my 30k gvw trailer has enough brakes to stop it with out touching the pickup brakes.
Old Sep 23, 2007 | 02:54 AM
Leader's Avatar
Leader
That is a true statement jetdock. Now think about the manufacturers changing the GCVWR just by changing the axle ratio or the trans. It has nothing to do with the brakes. It has nothing to do with safety. It doesn't matter that the GVWR stayed the same.
As for insurance, they pay if you are drunk and/or speeding, why wouldn't they pay if you are 100% legal but just over some manufacturers recommendations?
Old Sep 23, 2007 | 07:02 AM
glsurratt's Avatar
glsurratt
I believe it was the 2006 Ford Towing Guide has the following information which few drivers consider:
"Frontal area is the total area in square feet that a moving vehicle and trailer exposes to air resistance. The chart shows the limitations that must be considered in selecting a vehicle/trailer combination. Exceeding these limitations may significantly reduce the performance of your towing vehicle. Selecting a trailer with a low-drag, rounded front design will help optimize performance and fuel economy."
A Ford Superduty (F-250, 350, 450 and 550) all have a limit of 60 square feet. That means that your 8 foot wide truck and trailer should only be 7 1/2 feet tall.
Old Sep 23, 2007 | 07:07 AM
Leader's Avatar
Leader
And thats no more a "Law" then the GVWR or GCWR. If you haul a trailer with a frontal area greater then 60 sq et, your insurence will still pay.
Old Sep 23, 2007 | 08:47 AM
jetdoc's Avatar
jetdoc
And you'll pay too....in fuel costs!!!!
