2 Questions
Old Nov 4, 2008 | 02:28 PM
djflack501's Avatar
djflack501
2 Questions
My dad owns a '61 F-100 and we're try to find a bed for it the last owner ruined it letting it rust then just covering the rust with bondo -.- does anyone know where we could find one ... and second question we're not sure wha kind of motor is in it but were almost positive its not the original. how would we be able to find out whats in it. thank you for taking the time to read this hopefully you can help us out =)
Old Nov 4, 2008 | 03:44 PM
Sam_Fear's Avatar
Sam_Fear
Welcome. If you could post some pics to your gallery it might help, and we like pictures. It's gonna take a lot more info from you to get much of an answer.
If it's a V8 and there are 2 hold down studs in the middle of each valve cover (instead of along the sides) you have a Ford 292 Y-block - very common, otherwise, it could be anything.
Post all the info on the door tag too and someone will decode it for you.
As for the bed, is the cab and bed one piece (uni-body) or if they are seperate do the lines of the bed match the lines of the cab (the factory bed didn't match)?
Old Nov 4, 2008 | 07:02 PM
djflack501's Avatar
djflack501
Thanks for your help so far ... we're keeping the truck at my grand fathers so tomorrow when i go to clean it up I will take some pictures and get the info off the door tag. As for the bed its not a uni body their two seperate pieces and the lines do match up, when we pulled the bed off the original teal colored matched up on both the cab and the bed.
I will post back tomorrow afternoon and again thank you for your help
Old Nov 5, 2008 | 02:45 PM
djflack501's Avatar
djflack501
OK well first i uploaded some pics to my gallery.
I have the info off the door its:
Warranty #: F10DE625562
129 A F101 E81 A 07
I also got this number off the top of the motor(the guy at advance told me to look for a number on the block, which i couldnt find, but i did find this maybe it will help ID the motor if not it'll still be nice to know what it is =P) D5VE - 9425 - A3E
And lastly there are no hold down struts in the middle of each valve cover they are along the side
if anyone has any info for me it'd be great =)
Old Nov 5, 2008 | 03:57 PM
cobraguy's Avatar
cobraguy
The motor is an FE so it could be any of the following. 352, 360, 390, 428. I'd guess 352 or 360 the D5VE is a 1975 date code wich would be a smog era intake manifold. The grille is a 62 model. Welcome to FTE, Rich.
Old Nov 5, 2008 | 04:05 PM
cobraguy's Avatar
cobraguy
Ok I may be wrong I just took a closer look and it could be a 460 I get confused sometimes. Someone will be along shortly and decode the manifold # you gave.
Old Nov 5, 2008 | 05:38 PM
djflack501's Avatar
djflack501
^^^^ Thanks for looking and while I wait for someone to help me decode the numbers does anyone know if the manual steering can be changed to a power steering and how might we go about it. and is there any way to change the drum brakes to disc.
Thanks Cobraguy we appreciate all the help we can get =)
Old Nov 5, 2008 | 06:51 PM
Sam_Fear's Avatar
Sam_Fear
That warranty # is not from a '61. Either the door has been repaced or the truck is a different year ('65 I think). Was the truck black at one time? It looks like you may have a '65! Is the front end a straight axle or IFS? I don't see a pic of the bed - does it have round tail lights?
Old Nov 5, 2008 | 06:54 PM
Sam_Fear's Avatar
Sam_Fear
OK, looking closer, someone must have replaced the door or you mistyped the last 6 digits.
EDIT: Either give this thread some time and NUMBERDUMMY will find it and figure this all out for you or start a new thread called "VIN decode please" and mention the pics.
Old Nov 6, 2008 | 02:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by djflack501
F10DE625562 / 129 A F101 E81 A 07
I also got this number off the top of the motor (the guy at advance told me to look for a number on the block, which i couldnt find.
If you look on the block, adjacent to the starter, the bare block casting number is located there. This is what you'll find: D1VE-6015-AB, AB1, or AB2.
but i did find this maybe it will help ID the motor if not it'll still be nice to know what it is D5VE-9425-A3E.
Welcome to FTE
The engine is a 460 from circa 1975 thru 1978.
ID Number: D5VE-9425-A3E = Ford part number: D6VZ-9424-A .. 460 4V Intake Manifold.
Application:
1975/78 LTD/Mercury Marquis/Lincoln Town Car.
1975/76: Torino/Montego/Cougar/T-Bird/Mark IV.
1976/78: F100/350 & E250/350.
The 460 engine was not factory installed in F100/350's till 1973.
The VIN and the info off the Warranty Plate listed above: From the pics in your gallery, none of it matches the truck you have.
It's possible that a previous owner replaced the left door with one off a 1965 F100.
The info decodes to a: Black 1965 F100 Custom Cab Styleside Pickup with a 8' bed, 352 2V, red interior, assembled in Mahwah NJ.
The grille on your truck is from a 1962. The hood side emblem was used 1961/62. But after 40 + years, who knows what year it really is.
Hopefully, this will help...
1961/62: The Warranty Plate is not on the drivers side door. It's riveted to the inside of the glove box door.
Take a look, see what you find. Also look on the registration, see if the VIN listed there matches the one you posted above.
Sam Fear: 1961/64 Y blocks (292's) use a different cylinder head, with a valve cover that uses 8 bolts around the perimeter of the cover to retain it.
1954/60 Y blocks (239/256/272/292/312) use a different head/valve cover that uses two studs/nuts to retain it.
Old Nov 6, 2008 | 03:13 PM
djflack501's Avatar
djflack501
I don't think the truck was black ... if you look at the picture of the back of the cab you can see the teal color ... were guessing thats the original color and the red was painted on b/c to paint that they would have had to take the bed off (you cant see the bed b/c we took it off and i was standing on it when i took the pic of the back of the truck but its not 8 ft its about 6ft
The tail lights are round.
Numberdummy, thanks for all the info knowing the motor is gonna help ... so basically what your saying is the truck is def not a '61 it could be a '62 or a '65
Would the grill and hood emblem both be changeable to a '65 (basically would it be possible for someone to dress this truck up with parts from a '62 if it is a '65?)
Thank You for your help I'm going to look in the glove box for the info but im pretty sure its not their i only glanced when i was looking around it but i may have missed it so i'll look again
Old Nov 6, 2008 | 03:52 PM
NumberDummy
You still do not know what year your truck is, and neither does anyone else.
What is the Vehicle ID Number (VIN) that is listed on your registration? This is the definite answer to what year your truck is, what engine it had, etc.
Did you look on the inside of the glovebox door for the Warranty Plate (W/P).
That plate also has the VIN on it.
If a 1961/62, the W/P was there originally, not on the left door face below the latch.
Solid one piece front axle: 1961/64 / Twin-I-Beam = 1965/66 (2WD).
The hood is the same 1961/66.
The hood front emblem is the same shape 1961/66.
1961/64's are identical, the same one was used on 1965/66 6 bangers.
1965/66's with a 352 = V8 emblem.
1961/63: The trucks that have a separate Styleside bed use the same bed as was used 1957/60. It has round taillights.
This bed was not used after 1963, except on 4WD's and F350's.
It's possible this truck was wrecked at some time, the owner then installed a used front end off a 1961/62, swapped the 1961/63 bed.
But until you post the VIN as found on your registration, who really knows what it is.
Old Nov 6, 2008 | 04:42 PM
camperspecial65's Avatar
camperspecial65
This truck is POSITIVELY a 61-3 at least...3 front bumper bolts per fronont frame rail....
- cs65
Old Nov 6, 2008 | 05:18 PM
NumberDummy
Originally Posted by camperspecial65
This truck is POSITIVELY a 61-3 at least...3 front bumper bolts per front frame rail (aka frame horn)
- cs65
Good eye!
I thought I had looked at everything, but I missed the obvious.
The frame horns and front bumper changed in 1964, so it's gotta to be a 1961/63.
Old Nov 6, 2008 | 05:46 PM
camperspecial65
One other thing...most here know, some may not...ALL 61-4 trucks F100-250 2WD are straight axle trucks...65 up are twin I beam rigs...
Look on the passenger side top of the frame rail about center of it. The VIN is here...its about parallel with where the generator would be if you looked at it from the side of the truck which is around a foot forward or so of the main engine front cross member...
I dont have my VIN decoder, but the last 6 numbers and they WILL be numbers will tell you what year and what month the truck was assembled.
Also, IF your truck IS original as far as the glovebox door...THAT IS WHERE THE WARRANTY PLATE IS!!
Compare the frame number to the glovebox door and that will confirm the codes of the truck, etc.
- cs65
