zf 5speed
Old Nov 3, 2008 | 01:22 PM
Paul26's Avatar
Paul26
zf 5speed
i have a 1989 ford f150 with a 351w, my current tranny is a c6. i have been looking at a possible 5 speed tranny swap and have seen my two main options are the zf five speed and the mazda 5speed. i defenitly like the idea of the zf better and I was wondering what a complete list of parts would be to make this swap happen. any help is greatly apreciated, thank you.
Old Nov 3, 2008 | 02:53 PM
alxsnmr's Avatar
alxsnmr
Assuming your truck is a 4wd, Clutch, Flywheel, Clutch Master cylinder, hydraulic hose to the slave, Clutch/brake pedal assembly, possibly driveshaft lengthing/shortening.
Two-wheel drive will require a drive shaft that will allow for the 1/2 ton U-joints on the drive shaft and 3/4 ton Ujoints on the transmission where the transfer case would eliminate this problem.
Old Nov 4, 2008 | 08:42 AM
jas88's Avatar
jas88
Here's a pic of everything needed for a 4x4 that somebody sent me when I did mine:
Old Nov 4, 2008 | 03:22 PM
gravydude's Avatar
gravydude
Wow Jas88, That is a nice photo to hold onto for this reason!!!
Old Nov 5, 2008 | 09:27 AM
jas88's Avatar
jas88
I have posted it many times, this deal comes up about once a month it seems.
