windsor.....
Old Nov 2, 2008 | 07:32 PM
EVFD1559's Avatar
EVFD1559
windsor.....
got the top end back together.... and all the timing done... got her running and need to adjust the carb.... i believe it is around a 69 motor, does anyone know what heads are on this motor
Old Nov 2, 2008 | 07:37 PM
bashby's Avatar
bashby
you should've checked the casting #s, I think theyre on the bottom of the head. My D0oe heads take the big spark plugs, they are from 1969/70
Old Nov 2, 2008 | 07:42 PM
EVFD1559's Avatar
EVFD1559
mine are the big plugs.... and it takes the 69 style starter too.... ive heard the actual 79 heads are ****, and the older ones are better... is this true??
Old Nov 3, 2008 | 08:13 AM
Conanski's Avatar
Conanski
Both the older and newer heads are bettter than the smog era heads.. but they're all crap compared to what's available in the aftermarket these days.
Old Nov 3, 2008 | 08:59 AM
EVFD1559's Avatar
EVFD1559
well budget is short being i am still in highschool.... cant go blow 1400 dollars on aluminum...... but thanks guys...
Old Nov 3, 2008 | 09:00 AM
EVFD1559's Avatar
EVFD1559
also who makes a cheap set of headers.... im not too fond of the factory manifolds
Old Nov 3, 2008 | 12:07 PM
rockher_man's Avatar
rockher_man
casting numbers...
pull the valve covers off...
then check around the front of the heads near the mating surface
of the block...
good to doo
15
Feb 15, 2015 12:38 AM
eightball8
Apr 24, 2013 07:42 AM
ncpspeed
Feb 3, 2013 02:40 PM
oldmaninva
General Automotive Discussion
17
Feb 6, 2005 08:44 AM
BroncJMU
1978 - 1996 Big Bronco
Mar 1, 2004 06:44 PM
