Will 285/75-16 Rub?
Old Nov 16, 2008 | 09:27 AM
  #31
NS F250's Avatar
NS F250
Originally Posted by PwerStroke99
my wife even noticed it after i changed out rims, she hated riding in my truck before because it was so rough. She doesnt mind riding in it now, but still prefers her car
Did you get new tires with your rims? Does anyone else have issues with 285's on stock rims? I just ordered some 285/75/R16 Silent Armor Pro Grades for my truck, and now I don't know what to do. I don't want new rims, and I don't really want the ride to be bouncier than stock.
Old Nov 16, 2008 | 10:39 AM
  #32
cangim's Avatar
cangim
I ran my 285s on stock rim for about 2 years. No problems really noticed. I did run quite a bit lower air pressure empty to keep the tread riding flat. I didn't notice any bounce as others mentions. I do however like them better on the wider rims now. They are 8 inch vs the stock 7. I feel better running them with more air. Less tire roll when cornering.
Old Nov 16, 2008 | 11:31 AM
  #33
PwerStroke99's Avatar
PwerStroke99
i just swapped my old tires over to the new rims for now, because i dont need my new tires on the new rims yet. once we start getting some bad weather i will most likely put my new tires on the truck. I have a brand new set of MTRs sitting in the garage waiting to go on the truck.
Maybe i should rephrase what my truck was doing on stock rims. It wasnt necessarily more bouncy, but it definitely road rougher when i had the 285s on stock rims. the wider rims smoothed the ride noticeably to me.
Old Nov 16, 2008 | 03:57 PM
  #34
Neil64's Avatar
Neil64
Aftermarket Wheels
If I go with an aftermarket 16x8, is it likely to rub the spring with 285s?
Thanks...
Neil
Old Nov 16, 2008 | 06:26 PM
  #35
PwerStroke99
Thanks...
Neil
No, you will be just fine
Old Nov 17, 2008 | 04:43 AM
  #36
Neil64's Avatar
Neil64
Aftermarket Wheels
So an aftermarket wheel will stop the rub I am getting from my stockers and the 1" width will improve ride and the wearing of my BFG A/T 285/75/16s?
If so, I'll begin my hunt for wheels today.
Thanks...
Neil
Old Nov 17, 2008 | 04:47 AM
  #37
Neil64's Avatar
Neil64
Aftermarket Wheels
If an after market wheel will eliminate the rubbing of my BFG A/Ts, I was thinking about going with these: mounted on these rub?
Eagle Alloy Wheels
<table align="center" border="0" cellpadding="0" cellspacing="2" width="650"> <tbody> <tr> <td class="body_text_feature" align="center"> 0589-7887 </td> <td class="body_text_feature" align="center"> 16x8 </td> <td class="body_text_feature" align="center"> Polished </td> <td class="body_text_feature" align="center"> 8 on 170 </td> <td class="body_text_feature" align="center"> -11 mm </td> <td class="body_text_feature" align="center"> 4 </td> <td class="body_text_feature" align="center" nowrap="nowrap"> N/I </td> <td class="body_text_feature" align="center"> 3420 lbs. </td> <td class="body_text_feature" align="center"> 24 lbs. </td> </tr> </tbody> </table>
Does anyone know the stock polished 8 bullet hole style wheel's offset and other specs?
These are polished wheels that are not clearcoated. Anyone have any experience with the maintenance required to keep them looking good?
Thoughts?
Thanks..
Neil
Old Nov 17, 2008 | 10:07 AM
  #38
dyna's Avatar
dyna
DemonRace6, Did you use the stock rim (16x7) with your tires? I have 295x75x16 BFG's on the stock rims,But was told that they are too narrow for this size tire. I don't want to have to get wider rims if I don't have too.
Old Nov 17, 2008 | 10:10 AM
  #39
Neil64's Avatar
Neil64
OEM Wheels
Yes, I used an OEM 8 hole polished 16x7 wheel with my BFGs A/T TKO 285/75/16.
Neil
Old Nov 17, 2008 | 11:34 AM
  #40
Meatco1's Avatar
Meatco1
jdecker88
Were those E rated Michelin's you got for $400.00? If so, please let me know which Michelin design they are.
Respects,
Richard
Old Dec 22, 2008 | 09:04 PM
  #41
DemonRace6's Avatar
DemonRace6
Hi!
Sorry this is really late but yes they are on my stock rims.
But I want to know if I should be getting different rims and what kind, I want to go to 315x75x16 but I dont think i should do it on stock rims, if I want tires this big how wide should my rims be and should I go with larger rims??
Old Dec 22, 2008 | 09:18 PM
  #42
HKusp's Avatar
HKusp
AT least an 8 inch wide rim. I believe you want 305 70 r 16 not 75. That is a 35 inch tire in the old 15 sizes.
Old Dec 22, 2008 | 09:38 PM
  #43
DemonRace6's Avatar
DemonRace6
Hi!
305 70 r 16 tires are smaller than the ones I have on it now. I am putting the leveling kit on my truck and want to go with larger tires, such as the 315 75 16, but since I have to get new rims anyway I think I am going to get larger than 16 inch rims, is that a good idea??
Old Dec 22, 2008 | 10:11 PM
  #44
HKusp's Avatar
HKusp
Whoops, I meant 315 70's. It may be 75. I would go check my "new " ones but they are sitting in Sears' garage right now. They couldn't balance them so I have to take them to a 4x4 shop tomorrow at lunch.
You could go with a bigger rim, but it has been my experience that the larger the rim, the more the tires cost.
Old Dec 22, 2008 | 11:08 PM
  #45
DemonRace6's Avatar
DemonRace6
Hi!
Yea the cost is getting up there and I think I'm starting to cheep out and go with random brands instead of staying with the known good brands, what do you think about these package deals?
eBay Motors: 18" 18x9 Moto Metal 951 Black 325/65/18 Dick Cepek FCII (item 370134138711 end time Dec-28-08 14:16:49 PST)
eBay Motors: XD Rockstar Black 18" Nitto Terra Grappler 325/65-18 D (item 370092401908 end time Dec-30-08 16:40:17 PST)
