My truck is a '86 F-150, shortbed, 2WD, 300CI, 4-Speed overdive. Like many trucks of this vintage my fuel guage don't work (for now, but it will) and the only way that I can accurately know about the remaining fuel is by checking the mileage. So, I filled it up, drove for about 200 miles on Friday, then re-filled it, checked mileage and got what I thought was a respectable 17.6 mpg. That was with some 70-75mph interstate, and other mostly rural driving.
But still the question remains is what my tank capacity is?
My truck is a '86 F-150, shortbed, 2WD, 300CI, 4-Speed overdive. Like many trucks of this vintage my fuel guage don't work (for now, but it will) and the only way that I can accurately know about the remaining fuel is by checking the mileage. So, I filled it up, drove for about 200 miles on Friday, then re-filled it, checked mileage and got what I thought was a respectable 17.6 mpg. That was with some 70-75mph interstate, and other mostly rural driving. But still the question remains is what my tank capacity is?
117" and 138" Wheelbase (Shortbed):
Front Tank: 16.5 Gal
Rear Tank (optional): 19 Gal.
133" and 155" Wheelbase (long Bed):
Front Tank: 19 Gal
Not accorrding to the Ford Service Specification Manual. FPS 365-322-81
Shortbed Supercab is the 138" wheelbase.
Exact measurments 138.8"
It's a six inch difference from the 133" regular cab Long Bed.
Not trying to dispute your info but a Supercab short bed is built on the same wheelbase/frame as a reg cab long bed, thus 133". The only 138" wb truck Ford built is Econoline.
Ford Dissagrees with you.
Page Reference # 24-50-01 through 24-50-04 in the Ford Light Truck Specification Manual. FPS 365-322-81
F-150/F-250 SuperCab (shortbed) WB: 3526mm / 138" (138.8")
For the F-350 Chassis cab 3475mm (136.8) and 4084mm (160.8) Both use 19 gallon tanks.
There is also 3150mm (124") 18 gallon midship tank, and 3505mm (138"), and 3937mm (155") 22.1 gallon aft axle tank, listed for the Econoline.
Edit: The 1981 Ford Pickup Brochure backs up the Specification Manual. Center of page under Stylesyde Pickup Dimensions (4x2)
My appoligies to you, and after researching like I should have before challanging your post, your information is correct. Thanks for your precise information!
