Trying to put fuel rail back on injectors but am having a tough time, is it just simpley push and wiggle till they snap in or is there more to it.
(1990 f250 351)
thanks
steve
</TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
</TD></TR></TBODY></TABLE>
Lube the o-rings on the injectors with petrolium jelly or light grease, line them all up on 1 side at a time and the rail will seat with little effort. Make sure there is no corrosion or dirt built up in the sockets where the injectors seat, this is a big problem on the lower intake and something I usually clean out before installing the injectors.
