Turbo
Old Nov 1, 2008 | 08:36 PM
Skier041's Avatar
Skier041
Turbo
What is the stock turbo on a 97 Powerstroke. I have a Garrett on mine
Old Nov 1, 2008 | 09:52 PM
c00nhunterjoe's Avatar
c00nhunterjoe
that is stock, has no wastegate, has a 1.15 ratio exhaust housing and a 1.10 ratio intake housing. stock engines produce 15-19 psi boost.... lives a good life up to 25-30 lbs of boost.
past that they tend to come apart thanks to a thrust bearing set-up vs a ball bearing.
Old Nov 2, 2008 | 06:08 PM
Tim Shultz's Avatar
Tim Shultz
well hell I thought they where good up to 40PSI? I'm making 26-27PSI now and my stage twos will be here in a few days.. so am I going to blow that thing for sure? or will short busts of higher PSI not hurt it any?
Old Nov 2, 2008 | 08:13 PM
BlueMule's Avatar
BlueMule
30 is just about the limit. It only took a little over a month for me to wipe out the thrust bearing on mine with BDP stage I's and 32 psi. Beans D66 holds up to II's and I know of at least one person who is running one with 530 hybrids
Old Nov 2, 2008 | 08:15 PM
c00nhunterjoe
the head gaskets are pretyt good to 40 psi, the turbo...not so well.
Old Nov 2, 2008 | 09:02 PM
BlueMule's Avatar
BlueMule
HG's are good till past 50 as long as you do studs.
Old Nov 2, 2008 | 09:28 PM
c00nhunterjoe
right, with studs, but i am talking about stock engines and turbos
