Sponsored by: Kumho
OVERHEAT????
Old Nov 15, 2002 | 04:00 AM
mic's Avatar
mic
OVERHEAT????
I just recently installed a 3" bodylift on my 93 F-150 302,e4od
with a 6" suspension lift, I was just wondering since I didn't
install the radiator shroud back on (just won't fit without hitting
the fan) will I have overheating problems, I know putting on a electric fan would be the solution, but, I don't want to spend $210
for a fan if I don't have to.(flexlite 210 dual fan)..unless someone
has installed that shroud on with no problem, if so can you tell me
how you did it..
Old Nov 15, 2002 | 07:15 AM
msautry's Avatar
msautry
OVERHEAT????
Last truck I did a body lift on had the same problem - I cut the
bottom of the shroud out to clear the fan and bolted it back in place. Worked just fine.
msautry
Old Nov 15, 2002 | 06:35 PM
Ford_Six's Avatar
Ford_Six
OVERHEAT????
Shroud? Oh, you mean that plastic thing that always get in the way! I haven't had one on my truck since ever, and it has no problems. Not even when it was a 1-row radiator with a 351w behind it.
Jared
Old Nov 16, 2002 | 02:12 AM
Ryan50hrl's Avatar
Ryan50hrl
OVERHEAT????
68cabby
Feb 7, 2013 05:04 PM
05chop
Oct 17, 2007 02:44 PM
jsutton
Jun 25, 2007 06:06 PM
nikwave
20
Mar 2, 2004 07:17 PM
shakespearesdad
Nov 18, 2002 05:51 PM
