hard time starting.
Old Oct 31, 2008 | 11:39 AM
badltl510's Avatar
badltl510
hard time starting.
I have a 99 Expy EB I bought it used about 8mo ago It has a new motor the dealer put in before they sold it. It now has about 15,000 miles on the new motor. Everything seemed to be working good up in till about 2-3 weeks ago. In the morning I would go out and start it and it would start right up, but then just die. I would cycle the key off then start it again and it would be fine. Now I am starting to have the problem more often. I was noticing it was doing it the first time I would start it that day. Then this morning I went out started it and same problem tried cycling the key and this time it did not work I had to sit there for a few min with my foot on the gas to keep it running. I have the EATC. This morning When I held the gas down I noticed as soon as the heater came on it would idle on it's own. Is the EATC tied into the thermostat so that when the thermostat opens then the heat will come on? I thought this might be a good starting point but does anyone have any other ideas??
Old Oct 31, 2008 | 11:50 AM
Freak4Ford's Avatar
Freak4Ford
Start with the Idle Air Control valve.
Old Oct 31, 2008 | 02:19 PM
badltl510's Avatar
badltl510
I will take a look at that. I just drove it again this time nothing worked to keep it running. Even while driving if I would let off the gas it would die.
Old Oct 31, 2008 | 03:36 PM
badltl510's Avatar
badltl510
Pulled the IAC out cleaned it with carb cleaner and seems to work great. If it stops working again then I will just buy a new one.
james.mcafee1
Aug 8, 2010 03:42 PM
dickdowning
Nov 11, 2007 09:58 AM
taco709
Sep 23, 2007 05:47 PM
sfc2001
Electrical Systems/Wiring
Nov 18, 2005 05:19 PM
dpasciak
Sep 23, 2005 04:56 PM
