Sponsored by: Real Truck
Overdrive button blinking "off"
Old Oct 30, 2008 | 08:42 PM
Helene's Avatar
Helene
Hello all
I have very limited knowledge when it comes to anything mechanical--eh..so I am seeking help. I have a 99 Ford 350 Dually. Just today, going up a hill, the overdrive light started blinking "off" and my speedometer is not working. Everything else was fine. Gauges ok, shifting ok.
Any ideas? Is there a way of testing to get the troubleshooting codes yourself? Any help is appreciated.
Old Oct 30, 2008 | 10:06 PM
rbaker6336's Avatar
rbaker6336
Could be VSS or vehicle speed sensor on transmission or on rear axle
mine done that on occaisions and was the one on rear axle
it is located right of center on top of axle tube
Old Oct 30, 2008 | 10:08 PM
WhëëlMå1's Avatar
WhëëlMå1
Welcome to FTE. I know places like Autozone should be able to read your codes for free.
Old Oct 30, 2008 | 10:10 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I agree with the VSS diagnosis
Old Oct 30, 2008 | 10:21 PM
Helene's Avatar
Helene
Blinking overdrive "off"
Thanks all. So, would it be safe to drive it to a shop or is there a chance something will "blow" on the way? I am about 35 miles from town. Does the "overdrive blinking" relate to a lot of codes not even related to the tranny? I sure hope the VSS is whats going on. Thanks much again.
Old Oct 30, 2008 | 10:38 PM
micchicken's Avatar
micchicken
Mine has done that once pulling a boat out of the water up the ramp while turning in 4wh. I heard a little thud, the od light started blinking. I took it out of 4 wheel and turned the truck off. Started back up and all was good. Is yours still blinking?
Old Oct 30, 2008 | 11:17 PM
Helene's Avatar
Helene
I just started the truck up and the light is no longer there. It is too dark out to check the fluid levels etc but I guess the light being out it good. Do the codes/lights just go out like that?
Old Oct 30, 2008 | 11:30 PM
rbaker6336's Avatar
rbaker6336
the light may not be back for months or could be tomorrow but there should be a code stored
Old Oct 31, 2008 | 12:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The light will flash whenever the PCM sees something wrong. As long as it sees the error it will continue to flash. If there error is no longer there it will stop flashing. There is a code stored in memory when the light flashes. It will stay in memory for about a month after the last time the light flashed.
Autozone can't read Ford transmission codes, so don't waste your time there. You'll need a good trans shop or a Ford dealer to read the codes.
Most likely you have a failing vehicle speed sensor. It's developing an intermittent open circuit. You can drive it like that with little risk of damaging anything else. The sensor is cheap, usually less than $20, and it only takes one bolt to change it. It might be worth the risk of just installing a new one instead of paying someone at least 1/2 hour labor to read the codes.
turbo930ss
13
May 17, 2013 12:36 PM
TDD
Sep 1, 2009 07:16 AM
Tin Soldier
1997 - 2003 F150
Jan 31, 2008 06:28 PM
Renegade25
Jun 6, 2007 11:34 AM
searsk
Nov 3, 2005 07:33 AM
