Why front motor mount won't work?
Old Oct 30, 2008 | 03:12 PM
WALFORD'S 56's Avatar
WALFORD'S 56
Question Why front motor mount won't work?
Why won't a front motor-mount for a 56 work with a 1964 -292 yblock?
I got old front mount off--and now the 56 front mount won't install.
Need to know if front pulley is the problem or is it the 56 mount that is wrong?......Thanks..........Bill
Old Oct 30, 2008 | 04:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Need to know if front pulley is the problem or is it the 56 mount that is wrong? Thanks..........Bill
The bracket is different, the two rubber mounts are different.
These parts are the same 1961/64, different than previous years. Why? Because the 1961/64 engine crossmember is a different configuration.
Dunno if the harmonic balancer plays any part or not, but 1956 F Series trucks use a one year only balancer (also fits 1955/56 cars [not Birds] with 272/292's).
This balancer has been reproduced.
btw: 1961/64: While I've never searched for just the bracket, I do know that the upper/lower rubber mounts are available from several sources.
These front rubber mounts may be the same as the rears, it depends upon the application.
I'll search and type all the numbers, list who has them, if you wish.
Old Oct 30, 2008 | 06:33 PM
WALFORD'S 56
Thanks N.D.--I am ticked that this yblock is NOT a direct bolt-in to a f100 truck!!!
I have a few choices---Put yhis 1964 yblock 292 into the truck--and seems to be a weirdo of installation.....or put a 272 and 4 speed from the ''caterpillar'' 56 into this frame. Another choice is to install a 1991 302 and auto--or use my fmx trans that was in this frame with a 351 when I got it-but no engine!!!
I am told ALL yblocks fit into ALL 1956 ford F100 frames!!! NOT AT ALL!!! I am ticked!!
What should I do-----and my back problems are real bad now--so I only want to move just what I need to do--haha!! Bill
Old Oct 31, 2008 | 01:32 PM
Cyruscosmo's Avatar
Cyruscosmo
I have a V8 Y block out of a 1958 F100, the numbers for this engine are C2AE 6015 C, which works out to be a 292 cu. in.
I have never seen the mounting bracket that bolts to the engine for a 64 but I am thinking that if the Y block is supposed to fit anything a Y block came in then it stands to reason that your problem may be in the actual bolt on mounts and not the actual engine. The 58 292 I have is sitting on a pallet so I can get a good look at the mount bracket. Maybe it is different than the one that is on your motor and maybe it is like the one you need to mount that engine in your frame. 58 and 56 are a lot closer than 56 and 64… I will not be using the 292 which was pulled out of the parts truck I bought in favor of the original 223 I6 that came in the truck I am restoring.
Do ya have a picture of the mount you have?
Cyrus
_____________________
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... HELL YEAH!!! What a trip!
Old Oct 31, 2008 | 02:56 PM
WALFORD'S 56
Cyrus
Thanks---I have the 64 front mount --but had to cut it in 1/2 to get it off.
I have a 56 mount(front) and this looks noway able to fit behind the pulley.
I wish I had not cut off the 64 mount now!! It would not work anyway.
I will try to get a pic to show--still learning that trick!!haha
Thanks...Bill
Old Oct 31, 2008 | 11:12 PM
bigwin56f100's Avatar
bigwin56f100
You have to use a 56 mount with either a 56 front cover or a 56 crank pulley-balancer. 57-60 front mount is differnt, and the 61-64 is different than the 55-56 and the 57-60. They are all different and must be used with the correct cover and or balancer. I cant recall what is different but there was a write up in Y block magazine a few months back about this very problem. I believe and maybe wrong but I think the 54-56 truck crank pulleys were narower than the later. I forget but I will look for the article.
Kevin Bigwin
Old Nov 1, 2008 | 05:02 AM
NumberDummy
B6C6028A .. Engine Mount Bracket / 1954/56 239/256/272
Green Sales has one (800-543-4859)
Dennis Carpenter's NOS website shows two (704-786-8139)
These are NOS.
I also found the following NOS, but since they don't apply, didn't list who has them.
B7C6028A .. Engine Mount Bracket / 1957/60 272/292
C3TZ6028A .. Engine Mount Bracket-2WD / 1961/64 292.
Old Nov 1, 2008 | 06:18 PM
WALFORD'S 56
Thanks N.D. I will give them a call....and have alot to do this week , especially with winter coming fast.
Also going to meet Dave Boley this week,and he is buying my 53.
Hope to have engine and cab on 56 no.2 this week also--or next.
Barn is full and I am going to work on the 53 a little and put her in primer before winter.
The front mount is real wierd considering the engines are all the same. STRANGE!!
CharlieLed
Mar 5, 2014 11:15 PM
haven56
Sep 1, 2011 10:29 AM
sdetweil
13
Sep 20, 2010 12:32 AM
WALFORD'S 56
Oct 5, 2009 11:26 AM
regork
Jan 7, 2008 02:54 PM
